Press gas and car dies!Help!!!
Old Jul 18, 2007 | 01:24 PM
jgrogan's Avatar
Default Press gas and car dies!Help!!!
I put a 72mm bdl throttle body on my car. I ran into a problem. The car has trouble starting but when it does it idles a little high. Then when I give it gas it dies.
The car is going to be a turbo but I put the motor in without it. It is a 2.0l ls/vtec. It has ferra valves, bc dual valve springs and ti retainers, 3 angle valve job, p&p, type r cams and vitor x manifold. It is a gsr head.
The block is ge sleeves, arias 9:1 pistons,eagle rods,ls crank mircopolished and balanced.
Right now it is running on the stock gsr computer till I can get the turbo put in then it will be on hondata s300.
Please help me get the car running. Thanks
Old Jul 18, 2007 | 05:47 PM
NJIN BUILDR's Avatar
Default Re: Press gas and car dies!Help!!! (jgrogan)
If this is a new install make sure you really have the tps plug plugged into the tps.There is another plug with the same end on the wire harness.
Old Jul 18, 2007 | 09:12 PM
jgrogan's Avatar
Thanks man I have been stressin over that pretty hard. I feel like a noob. Maybe cause I am. Thanks for learnin me.
lilbinky
May 20, 2013 06:42 AM
Critikul
Oct 13, 2012 07:24 PM
maxum17ft
Sep 5, 2007 09:14 AM
boosted k20
Sep 29, 2004 12:42 AM
