coolant leak.....help!!
ok i have a 93 prelude si h23......well this morning i was going to the smog shop when th vehicle suddenly started over heating .....i pulled up to a liqour store near by shut it off and got water.....i put 2 bottles of water in were the cooalnt goes and then the car seemed to b fine i drove it for like one hour with no problems temp is fine and everything but then i noticed that water was leaking from wat appears to b the side of the engine were the belts are......those this mean its a bad watr pump? or wat could it b? is there anything i can do to fix it....i no theres radiator fix liquid but its not coming from the radiator so i dunno help me please
you sure of the source of the leak? if it's a leak coming straight out of the block, i wouldn't know... i would think water pump but can't say for sure.
other possible sources are of course your radiator, your hoses, water pipe... take a closer look and see if you can pinpoint it.
and don't bother with any radiator fix GUNK because it's garbage and only a band-aid. maybe only in an emergency.
umm ok its coming from behind the engine bottom part of block but over oil pan i dunno its leaking bad but just when i turn it on ....when the car is off it dont leak anymore.....is it the water pump seal?
