Swapping distributor's
Many people on this forum suggested swapping dizzy's with a friend to see if it was the cause of a particular problem.....
My question is about the timing of the car putting the dizzy on. If I take a dizzy off a friends car after marking it (to put back in correct place) and I put it on the car being tested, will that mess up the timing of the car or is having the timing close enough okay.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcdcdc »</TD></TR><TR><TD CLASS="quote">Many people on this forum suggested swapping dizzy's with a friend to see if it was the cause of a particular problem.....
My question is about the timing of the car putting the dizzy on. If I take a dizzy off a friends car after marking it (to put back in correct place) and I put it on the car being tested, will that mess up the timing of the car or is having the timing close enough okay.</TD></TR></TABLE>
Having the timing close enough for a short amount of time is perfectly fine.
exactly the answers I was looking for, thanks to both you guys.
im an idiot, when I took my dizzy off after marking it, i decided to clean off the oil and accidently erased the marking on the dizzy. time to bring out the timing gun?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dcdcdc »</TD></TR><TR><TD CLASS="quote">exactly the answers I was looking for, thanks to both you guys.
live and learn
live and learn
philosofy1
Feb 1, 2008 04:43 AM
