Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
How hot does an exhaust manifold get? Mine is cracked and I just want to do a quick fix until I get
Old Jul 18, 2007 | 09:25 AM
Xmar's Avatar
Default How hot does an exhaust manifold get? Mine is cracked and I just want to do a quick fix until I get
How hot does an exhaust manifold get on 2001 1.7 L LX civic? Mine is cracked and I just want to do a quick fix until I get all the part in. I have a 2001 LX civic and wanted to use Alumiweld to fix it but it's working temperature is 730 degrees F.
Old Jul 18, 2007 | 09:43 AM
Relic1's Avatar
yah, at times you can almost double that for the gasses going through it. I'm not sure how hot the actual manifold gets, but I'd bet it's more than 750*F.
Permatex makes stuff for exhaust patching, you may want to look into that at your local parts store.
edit: part #26346 is what I'm thinking of .... http://www.amazon.com/Permatex...LBZMG
Old Jul 18, 2007 | 09:59 AM
Xmar's Avatar
Default Re: (Relic1)
Hey Relic,
Thanks man! Didn't know about the Permatex stuff.
I will use it instead. Thanks again.
Old Jul 18, 2007 | 10:06 AM
Relic1's Avatar
no problem.
be sure to post how it works.
Old Jul 19, 2007 | 03:23 AM
sujak's Avatar
um alot hotter than 750
Old Jul 19, 2007 | 07:45 AM
toyomatt84's Avatar
Sanji
The hottest exhaust temperatures should get, would be around 1400 degrees Fahrenheit.
Old Jul 19, 2007 | 01:41 PM
da1lydr1ver's Avatar
Default Re: (toyomatt84)
dont waste your time with the exhaust patches, it will not work, i promise you. the exhaust, not to mention the manifold (which gets even hotter), will heat up so much that the patch will just burn in a matter of minutes. plus, on a LX model, the cat sits on the exhaust manifold, so it will get even hotter than a manifold without a cat.
just get yourself an new manifold or header.
Old Jul 19, 2007 | 01:45 PM
i-VTEC_DOHC's Avatar
when i go touge with my crew my headers glow bright orange.. so however hot that it is lol
2001dxtn
May 3, 2012 06:31 AM
LordAphotic
Nov 18, 2010 03:43 PM
abmerop18
May 17, 2006 04:58 PM
