Power lock does not work.
Old Jul 18, 2007 | 07:23 AM
arowana23's Avatar
Default Power lock does not work.
1998 Civic Power lock does not work when I hit the switch. I have factory alarm it will arm the car but will not lock. I replaced the power lock control box and also the power lock switch. What should I do? Any help woul be appreciate.
Old Jul 18, 2007 | 11:06 AM
arowana23's Avatar
Default Re: Power lock does not work. (arowana23)
Help please
Old Jul 18, 2007 | 12:14 PM
MatterMatt's Avatar
Are all of the power locks inoperative, or just one? Please clarify. If just one is inoperative the likely cause is a bad power door lock actuator. You will need a manual to perform the appropriate actuator tests and have a troubleshooting flow chart.
Old Jul 18, 2007 | 12:24 PM
arowana23's Avatar
Default Re: Power lock does not work. (MatterMatt)
All doors not working. I checked the fuse.
Old Jul 18, 2007 | 01:37 PM
arowana23's Avatar
I dont think that is the case b/c when i hit the switch on the door it still does not work.
Old Jul 18, 2007 | 02:04 PM
MatterMatt's Avatar
Check the relay. Grab a manual too.
Chris55
Jul 22, 2017 01:40 PM
j3rz3yb0y
Mar 2, 2013 01:35 AM
batallic
Sep 29, 2010 04:17 PM
seatown206
Honda Civic (2001 - 2005)
Mar 28, 2010 06:51 PM
4playEkay
Mar 31, 2005 10:48 PM
