99 00 PWR WINDOW/LOCK/MIRROR CONVERSION
Okay, just last night I finished my power window/door look/mirror conversion on my 99 hatch DX. I bought a set of 00 SI doors complete and the floor harness. I installed the doors and connected the new harness and the windows work and so to the mirrors but the door locks dont work. I am not sure what I need to check to see what may be the problem so any help would be very much appreciated, thanks.
That i did not, i will need to find one. So once i get that is there a connection that i hook it up? is it off the floor harness?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hans Moleman »</TD></TR><TR><TD CLASS="quote">If you don't mind me asking you, how much $$$ did all this run you? I'd like to do the same to my DX. </TD></TR></TABLE>
I bought the complete SI doors for $220 from an H-T member(RHD DA6
), $90 for the floor harness from an H-T member (ekHamst3r
), mirror switch from ebay for $10, and the power window relay from Honda for $10.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by monicle »</TD></TR><TR><TD CLASS="quote">yeah it should connect to the floor harness
he is the man,
i got my information from him!
he is the man,
does anyone have a picture of the lock control module? I went to this used honda parts place in garden grove and they gave me this box that was blue and said that it goes in the driver side door and connects to the harness in there. I got home and looked inside the door and didnt find anywhere to connect it too
. Then I checked in the kick panel and didnt find a connection that matched up to it. Is there a difference in the lock control modules between the 99 00 ex and si?
The 99-00 power lock module/controller is white. I forgot what words were written on it. The harness that connects to it is on the dash harness I believe. I know it's not attached to the floor harness. When I pulled the module off the wrecked Si, I just cut the harness that connected to it and wired it into my floor harness.
Half the wires that went into that lock module were not needed to get the power locks fully functional. I think they were for the factory keyless entry system. Good luck hunting down the parts.. I was lucky enough to pull parts off a wrecked Si.
i think any 99-00 model will be fine... 96-98 is on the door and it blue, and like the previous guy mention 99-00 is under the dash...and it a white box...good luck bro
I need help ASAP! please! I have a 97 hatch w/rear wiper but my harness is a 99 ex keyless entry. I still have the EX and everything from it. Is there an easy fix for the plugs? I'm not sure what wires go where I have a repair manual but its kinda crappy. Could I just take my EX rear harness off then repin the plug for the wiper? Any info would help. Oh and I would rather not change the dash harness. I'm needing to know ASAP so I can get to IA fall meet.
YEA I'M DOING THE CONVERSION ON MY 99 HATCH. I GOT THE FLOOR HARNESS FROM A 2000 CIVIC SI AND WINDOW HARNESS WELL I HAD TO RE PIN THE REAR MAIN CLIP AND FRONT MAIN CLIP THE 2000 HARNESS CLIPS FRONT AND REAR IS SMALLER AND MY 99 HATCH CLIP IS BIGGER SO I HAD TO REPIN THE CLIPS FRONT AND REAR, SO I ALSO ADDED THOSE 3 WIRES MINT/BLACK,-MINT, DARK GREEN WIRES SO MY REAR WIPER WOULD WORK. SO EVERY THING PLUGGED IN AFTER A LITTLE RE PINING BUT MY WINDOWS AND MY FRONT SPEAKERS DONT WORK SO I ADDED DIRECT WIRES TO THE BATTERY TO THE DRIVER SIDE BUTTON HARNESS AND IT WORKS, AND MY REAR WIPER STAYS ON THE WHOLE TIME THE CAR IS TURNED ON DONT KNOW IF I CROSSED WIRES SOMEWHERE ... NEED HELP THANKS
DAPhatch99
11
Apr 4, 2014 05:54 PM
jspecb18vtec
Aug 11, 2010 08:42 AM
1990, 2000, 92, civic, conversion, converstion, coversion, ef, hatch, honda, locks, power, si, window, windowslocksmirrors
