for people using chop saws to make collectors please help
Old Jul 18, 2007 | 06:48 AM
crxsir23's Avatar
Default for people using chop saws to make collectors please help
OK i can make collectors all day long out of pvc but when i make it out of 304 the plade flexes when its at the end of the cut really pissing me off
Old Jul 18, 2007 | 08:29 AM
danielm3's Avatar
Default Re: for people using chop saws to make collectors please help (crxsir23)
Go really slow and don't push on the handle, let it cut it self. It will take longer, but the cut will be a lot more straight.
Old Jul 18, 2007 | 08:58 AM
RC000E's Avatar
Default Re: for people using chop saws to make collectors please help (danielm3)
Wow....collectors with a chop saw....that has to be rough. I do mine on a bandsaw and still b*tch. It took me months to finally produce all but perfect pieces. Did you make a jig for the chopsaw or do you do the sharpie/vice grip method?
Old Jul 18, 2007 | 03:53 PM
crxsir23's Avatar
Default Re: for people using chop saws to make collectors please help (RC000E)
i have a jig that works really well but when i get to the end of my cut it Fs-up every damn time how much angle do you guys use maby im using to much angle for the blade not to flex i doubt that's my problem though
Old Jul 18, 2007 | 06:32 PM
RC000E's Avatar
I do 28-34 degree collectors depending on what I'm making.
Old Jul 18, 2007 | 06:41 PM
*Boostwerks*'s Avatar
Are you using a fiber blade? I'd try out a carbide tipped metal blade. It deflects a lot less than the fiber stuff, and lasts a lot longer. Just make sure you go slow.
Old Jul 18, 2007 | 07:38 PM
crxsir23's Avatar
Default Re: (Boostwerks.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boostwerks.com &raquo;</TD></TR><TR><TD CLASS="quote">Are you using a fiber blade? I'd try out a carbide tipped metal blade. It deflects a lot less than the fiber stuff, and lasts a lot longer. Just make sure you go slow. </TD></TR></TABLE>
yes,
i thought about that dint think it would work ill gave that a go if it don't work il go and get this
Capacity Rectangular: 4in. x 6in.
Capacity Round Stock: 4.5in.
Motor Size: 1/3 HP
Input Volts/Amps: 115 / 6
Angle Cuts: 45° to 90°
Horizontal/Vertical: Horizontal / Vertical
Blade Speeds (fpm): 80 / 120 / 220
Blade Size: 64.5in. x 1/2in.
Overall Size: 36in. x 12in. x 37in.
Stand: Steel Stand
Included Accessories: Miter Gauge Vise
Model: 15574
im at work cant show pics or look at **** lol
Old Jul 19, 2007 | 05:04 AM
crxsir23's Avatar
Default Re: (crxsir23)
sent a IM to RCOOOE
Old Jul 19, 2007 | 09:20 AM
KFMRC's Avatar
you better have one hell of jig to use a carbide and also the carbide blades are not replacements for the normal chop saw. The carbide blades are for saws that are designed for them that spin at half the speed of a normal abrasive saw.
The carbide saws work great but there is no forgiveness for something that is not held rigid. It will rip it out of the saw unlike the abrasive saw. The Makita lc1230 carbide chop saw comes with a much better vise setup then its abrasive counterpart. I have both
Modified by KFMRC at 3:05 PM 7/19/2007
lamonte619
Nov 10, 2010 07:57 AM
ej1 rep
Sep 24, 2007 08:14 PM
Modify
Feb 1, 2005 06:58 AM
paulzy
Dec 27, 2004 08:57 PM
mattduskater
Nov 3, 2003 06:20 AM
