Fuel Problem please help
I have a 92 cx with a ls-vtec swap anyways I just got the car back together and I go to start it and I am not getting any fuel pressure and the pump is not kicking over either does anyone know if there is a fuse that is blown are a ground that I could have possibly missed any help would be sweet i am ready to drive this thing thanks
Check the ground wires, i had the same prob a week ago and my homie took it to the shop, he didnt ground a wire when he did the swap. It was the wire that grounds on the back of the engine from where the radiator hose goes to(from bottom radiator hose to back of engine) , try that or just check all your ground. LMK how it goes
if you checked all your fuses, and still nothing, check your ECU fuse in the engine bay, and if thats not the case, try swapping out the main relay.
If none of those are still not solving, get a new fuel pump
bacnoonoi
Oct 10, 2008 08:31 AM
clubeg
12
Mar 19, 2006 09:28 PM
