B17A1 turbo setup
Anybody running a B17A with turbo? I'm planning on doing this, and would like to know what hp to expect. I've been debating between all-motor and turbo, and I think turbo will make me happier. I plan to get a DRAG kit from Ben at ImportParts. I know they have a DRAG 2 kit for my car, I was wondering if they make a DRAG 3 for it yet? Could I expect 250 whp on stock internals?
That should satisfy me for the time being. But I though the DRAG kit would have me running around 7 psi on a stock setup. If this is true wouldn't I be putting out a little more whp.. like maybe 230. Come on guys.. I need some opinions and advice.
u can put down as much power as 250whp....running 7-10 psi safely
fuel setup needs to be accurate
timing will need to be adjusted
u can definetly put down 250 whp with a gsrb17a with a drag kit, im guessing fmu+inline.....? in order to run that safely i would go with a better fuel setup and hondta= 450's,550's+stock pump+hondata tuned....
im me and we'll b.s. about DA setups.
Cool, thanks for the info. So would a Hondata Stage 2b with some larger injectors work ok? I was thinking about RC Engineering 310cc, but I'm wondering if that would be big enough. Keep the info coming.
