car wont start plz help
CEL is on with no codes, i have a d15b vtec on a pm6 ecu, i changed the ecu to a jdm pr3 still the same problem, CEL is on with no codes and no spark, what is the problem here? it starts from time to time though, but i got tired from this plz help
bump, i just bought a new battery and installed it, the car ran for a sec, then i tried to start it again it gave me the same problem, CEl is on without codes, and no spark?! main relay?! maybe?! oh and after 2 hours i came to tried it again but there's no power in the car like it doesnt have a battery
Are you running obdo or 1?
Does the car crank anymore?
Could be the wrong ecu for the car
Could be starter
No spark could mean main relay. Crack it open and resolder the points.
Troubleshooting is so fun.
Could be starter
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HcBrKx »</TD></TR><TR><TD CLASS="quote">Are you running obdo or 1? </TD></TR></TABLE>
OBD0 i mentioned the PM6 ecu
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HcBrKx »</TD></TR><TR><TD CLASS="quote">Does the car crank anymore?</TD></TR></TABLE>
yes it does
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HcBrKx »</TD></TR><TR><TD CLASS="quote">Could be the wrong ecu for the car</TD></TR></TABLE>
ofcrs not
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HcBrKx »</TD></TR><TR><TD CLASS="quote">Could be starter</TD></TR></TABLE>
its fine like a hornet
No spark could mean main relay. Crack it open and resolder the points.</TD></TR></TABLE>
i dont know how to do that
yes it does
ofcrs not
I could be wrong, but isn't the pr3 obd1?
Thats why I asked what obd you were running.
If you don't try and fix ur main relay, find a replacement. Usually you'll know its bad when you turn your key over and the yellow engine light doesn't come on, or it doesn't click. You should be able to hear the fuel prime, and the clicking sound.
My CRX has been starting, adn then not starting and I think its the main relay.
It really comes down to fuel, spark, timing, and the starter. Gotta check everything
the CEL is on but doesn't flash any codes? Key on, under the carpet?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HcBrKx »</TD></TR><TR><TD CLASS="quote">No spark could mean main relay. Crack it open and resolder the points.</TD></TR></TABLE>
^ I would try this too. search "main relay" in the EF forum, there are plenty of pics & how to's
spyz34
Mar 20, 2005 12:49 PM
xenocron
Jan 2, 2004 07:38 PM
