MAP sensor Q
Hey are the map sensors from 92-95 civics interchangeable!? Reason im asking is cuz i have a 93 Honda civic LX and i currently swapped my engine with a JDM D15B and i have a extra map sensor for the one that goes on top ot TB. My car has it next to firewall. Will changing my TB with the other map sensor that goes on TB better for Vtec engines or is it the same? Any input is greatly APP.
it should be the same. idk about the jdm engines but the usdm's are all the same. check the part numbers on autozones website if ur still not sure. i dont see why a jdm one would be diff but who knows.
Well my JDM engine came with the TB that requires map on top of TB! So im just wondering if there is a power diffirence if im using my old engine map sensor setup, and if using the other method would be better?
well like i said all the usdm's are the same. from 92-00 civics. as far is i know i cant tell you about the jdm ones. so as for the usdm's wather its on the firewall or tb its the same part and part number.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DCSportEJ1Civic »</TD></TR><TR><TD CLASS="quote">well like i said all the usdm's are the same. from 92-00 civics. as far is i know i cant tell you about the jdm ones. so as for the usdm's wather its on the firewall or tb its the same part and part number.</TD></TR></TABLE> Actually my map sensor reads part PS-22 and the Ex/si vtec ones are PS-30.Also ive noticed that the only one that have in top are vtec engines not the non vtec engines like the one i had before D15B7 Turtle motor! Does anyone know if the D15B TB is wider in daimeter than the D15B7 Or are they the same in mm.?
there the same i have a box of map seniors from accords to civic to prelude there all the same even the one on my s2000 works it just all depends on the year if it's 0bd0 or obd1 or 2
Soichiro-son
Sep 6, 2005 06:48 PM
Soichiro-son
Aug 19, 2005 06:35 AM
Yellow Dragon
Jul 23, 2003 02:01 PM
