Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Turbo kit with Auto-Trans??
Old Jul 17, 2007 | 08:50 PM
baiwldrnner's Avatar
Default Turbo kit with Auto-Trans??
You guys think it's worth it getting a turbo kit, even for an automatic transmission?
Old Jul 17, 2007 | 08:52 PM
sujak's Avatar
why wouldn't it be? You'll still have a 60-80% increase in hp/tq
Honestly do you guys think just cause you have an auto the turbo doesn't do anything than? it will do the exact same damn thing as it does with a manual car just less hp/tq @ the same psi due to all the mechanics in the auto-transmission.
Old Jul 17, 2007 | 08:58 PM
EM2ner's Avatar
Default Re: (sujak)
I think it would be better cause you can hold your boost longer without letting off the gas to shift.. just pork it and go.. IMO
Old Jul 17, 2007 | 09:05 PM
Boilermaker1's Avatar
there's nothing wrong with it...
just dont expect the tranny to last long.... more torque = more heat = more wear = poof.
Vantage's Avatar
be ready to buy numerous trannys. automatic trannys are notoriously bad and will probably break after only a few thousand miles.
Old Jul 17, 2007 | 11:02 PM
DsevenEm2's Avatar
anything we can do to prevent that break? or...delay it....by the way..good thread noob.
Old Jul 18, 2007 | 09:37 AM
Default Re: (DsevenEm2)
....sry for learning.
Old Jul 18, 2007 | 10:08 AM
daddy's Avatar
Default Re: (baiwldrnner)
sujak is just being an *** again. theres nothign wrong with ur question imo. you wanna make ur car fast like most of the rest of us. and your trying to work with an auto tranny so its an honest question. not everyone has a 5speed to work with
Old Jul 18, 2007 | 11:16 AM
Curiouz_G's Avatar
auto trannies can be beefed up to handle the extra hp/tq... get a auto tranny, send it to TCI, get their overhaul kit, and youll be good to go. just expect to spend around 1k for it. but with that, youll be able to handle 200whp with the tranny with no problem.
Old Jul 18, 2007 | 11:17 AM
Curiouz_G's Avatar
Default Re: (Vantage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vantage &raquo;</TD></TR><TR><TD CLASS="quote">be ready to buy numerous trannys. automatic trannys are notoriously bad and will probably break after only a few thousand miles.</TD></TR></TABLE>
no need if done right
Old Jul 18, 2007 | 01:07 PM
Default Re: (Curiouz_G)
Wow! Better start saving, lol! Thanx for the pointer!
Old Jul 18, 2007 | 01:49 PM
sujak's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baiwldrnner &raquo;</TD></TR><TR><TD CLASS="quote">....sry for learning. </TD></TR></TABLE>
you can send the tranny out to TCI as said below i think i've seen 1 or 2 people do that or buy an Overhaul kit which basically replaces the weak parts in the tranny
you can also just try a tranny cooler and whatever happens happens
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 03turboem2 &raquo;</TD></TR><TR><TD CLASS="quote">sujak is just being an *** again. theres nothign wrong with ur question imo. you wanna make ur car fast like most of the rest of us. and your trying to work with an auto tranny so its an honest question. not everyone has a 5speed to work with</TD></TR></TABLE>
no i was trying to be nice to him
Old Jul 18, 2007 | 07:21 PM
ryan_61684's Avatar
Default Re: Turbo kit with Auto-Trans?? (baiwldrnner)
I have a 05 civic auto tranny as well. I want to turbo charge but with a maual trans so I started searching salvage yards. found one with 22k miles for $550. So if you want to spend a bit more to be on the safe side, I dont think it would be a bad idea.
good luck
Old Jul 18, 2007 | 08:53 PM
Default Re: Turbo kit with Auto-Trans?? (ryan_61684)
I'm might go for the swap . But I wanna ask, what parts do I need for the swap, besides like getting a clutch pedal and stuff like that?
Old Jul 26, 2007 | 09:07 AM
thinknology's Avatar
I've never messed with purchasing or installing a turbo... what kind of precautions/parts do you need to get before turbo-ing a d17, aimed for low boost?
Old Jul 26, 2007 | 09:14 AM
daddy's Avatar
Default Re: Turbo kit with Auto-Trans?? (thinknology)
look in the FAQ there is a turbo for noobs thread in there
Old Jul 26, 2007 | 10:16 AM
Default Re: Turbo kit with Auto-Trans?? (03turboem2)
MM YA... i finally found what i was looking for... you'de think i've been here for awhile i shouldn't make stupid noob mistake, my bad... to me
Old Aug 7, 2007 | 10:33 AM
missionaryrider's Avatar
hey, i have a 93 ls tubo and b4 u put the money into turboing it i would strongly recomend going 5 speed, mine sucks big *****.
if u want any jump off the line, u wont get any it falls on its face even with trying to boost off the line the 1st gear is to slow u have a while b4 u get any power, its wosst off the line then without the turbo cuz of turbolag and sucky 1st gear.
but on the good side if u can get the strength up and switch the gear it would be baddass.
cuz i have mone on 7 lb. and it drops to 5 lb when the gears switch and the right back to 7 so ur boosting the whole time.
just my 2 c
Old Aug 7, 2007 | 04:28 PM
DankasCivic's Avatar
TCI makes a rebuild kit for 7thgen auto trans it cost like $300 and another $2100 to have someone install it. The kit will hold up to boost but at the extra cost not worth it imo but hey its a option you can take to make sure it will not go kaboom flogin the crap out of your car.And while your at it get a transmission cooler for another $150 just to keep temps cool the one built into the radiator is worth **** And of course now I saw that someone has already mention this what a day its been shesh
Old Aug 9, 2007 | 12:55 AM
1llmatic's Avatar
New User
Default Re: (DankasCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ryan_61684 &raquo;</TD></TR><TR><TD CLASS="quote">I have a 05 civic auto tranny as well. I want to turbo charge but with a maual trans so I started searching salvage yards. found one with 22k miles for $550. So if you want to spend a bit more to be on the safe side, I dont think it would be a bad idea.
good luck</TD></TR></TABLE>
clutch pedal, brake pedal, clutch master cylinder, lines, Manual transmission, brackets, shifter cables, shifter assembly, etc.
there's probably a listing for parts and instructions somewhere...
Old Aug 10, 2007 | 02:00 AM
riceball777's Avatar
Default Re: (1llmatic)
its preatty common knowlege that honda auto trannies and boost do not mix.
honda auto transmissions are just too weak
Old Aug 12, 2007 | 03:38 PM
kam_101's Avatar
Hell yea an automatic turbo is tight
Old Aug 12, 2007 | 08:54 PM
hondaexshark's Avatar
Default Re: Turbo kit with Auto-Trans?? (kam_101)
I say get urself a trans swap. Then work on ur Turbo later...
I have an auto an it won't keep up...
Old Aug 13, 2007 | 12:08 PM
daddy's Avatar
Default Re: Turbo kit with Auto-Trans?? (hondaexshark)
prolly easier to just sell the automatic and buy a 5speed!
Old Sep 10, 2007 | 03:08 PM
thascientist25's Avatar
Default Re: Turbo kit with Auto-Trans?? (daddy2be)
i might plan on a tranny swap sometime in the future but i was just wondering how much it all came out to be roughly..
cuz i have an 05 auto and i'd really like a swap
