Car Won't start 95 civic
Old Jul 17, 2007 | 08:21 PM
SoHc Ej1's Avatar
Default Car Won't start 95 civic
I have a '95 civic and it won't start. There is power, my oil and battery light and my ignition will click but it won't start.I got it started the day before and it made a wierd sputtering noise but then clicked over and started up and ran fine. Any ideas?
Old Jul 17, 2007 | 09:04 PM
slo_ek9's Avatar
Default Re: Car Won't start 95 civic (SoHc Ej1)
i would start with the obvious and check for fuel and spark. also make shure you have a good battery might just be a dead battery(or starter) if all it does is click
Old Jul 17, 2007 | 09:14 PM
SoHc Ej1's Avatar
Default Re: Car Won't start 95 civic (slo_ek9)
battery is good because the lights are turn on and doesn't fade plus it wont start when i try to jump start it. It has fuel and i changed my spark plugs about 4months ago
Old Jul 17, 2007 | 09:18 PM
red02s2k's Avatar
there could be so many things you need to explain your symptoms better... you could try checking your distributer cap and rotor
Old Jul 17, 2007 | 09:23 PM
SoHc Ej1's Avatar
Default Re: Car Won't start 95 civic (red02s2k)
that's true, it could be so many things. I'll figure it out tomorrow thanks for the help guys
Old Jul 17, 2007 | 09:24 PM
1995Civic's Avatar
Does it just keep turning over, and wont start?
Old Jul 17, 2007 | 09:25 PM
SoHc Ej1's Avatar
Default Re: (1995Civic)
no it wont turn over, it makes a click noise
Old Jul 17, 2007 | 09:29 PM
1995Civic's Avatar
Default Re: (SoHc Ej1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SoHc Ej1 &raquo;</TD></TR><TR><TD CLASS="quote">no it wont turn over, it makes a click noise</TD></TR></TABLE>
That sounds like a bad starter, which is where i would start...I dont think it's your rotor because the motor would at least be attempting to turn over.
Old Jul 17, 2007 | 09:30 PM
SLO Sol's Avatar
do you hear your fuel pump click off?
do you have spark? pull a plug and ground the end and see if you see a spark if not it could be anything. my eg has a problem burning out dizzys
Old Jul 17, 2007 | 11:08 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: (D-money 92si)
If it only makes a clicking sound it sounds like a starter issue. Borrow a friends if possible and see if she starts up
Old Jul 18, 2007 | 12:20 AM
red02s2k's Avatar
if it is just clicking try ground from the starter
Old Jul 18, 2007 | 08:45 AM
SoHc Ej1's Avatar
Default Re: (red02s2k)
thanks guys, it was the starter. The ground wire that connects to it was severed and i replaced it so it runs good.
lilshady6796
Aug 17, 2009 04:58 PM
po0tie
Feb 17, 2008 09:46 AM
posterchild
Jun 26, 2004 02:09 PM
lowblazin
Nov 25, 2003 10:00 AM
