Problems with sound quality, need some advise.
So, i have a 04 tsx and i had some stuff laying around i decided to install in the car. I have an LOC, fosgate punch amp, punch p1 sub. Just got done setting everything up and it sounds like ***. Theres barely any sound coming from the sub. From what i might have figured, Im afraid the factory amp may be sending a shitty signal through the LOC. Ideas?? Yes Yes i know LOC suck, but tell me who sells a dash kit for a TSX and ill be all over it. Thanks in advance.
Chances are good, you mis-matched the wires from the loc. If wired backwards, the phase would be 180degrees off alignment and cause a cancellation. Check your wiring to ensure the pos and neg are terminated at the correct wire.
Yes, loc's suck. And yes, factory amps have shitty signals. In this case though, you might just remedy the issue by checking your loc.
We could make you a dash kit
derekcentrico
10
Aug 29, 2011 07:43 PM
