Rod Bearing lubrication issue
Old Jul 17, 2007 | 04:40 PM
DecentCivicZ6's Avatar
B A N N E D
Default Rod Bearing lubrication issue
Ok, I was just playing around with a stock set of rod and piston. I notice the stock rods have a hole drilled thru the rod all the way thru bearing and all. Also notice my ACl race bearings have a hole drilled in them. So why the hell does my H beam rod not have ANY holes at all? Should I get the machine shop thats putting this together to drill a hole? and if so, just 1 hole per rod and its gotta be matched thru the hole on bearing also im guessing. Just making sure my guess is right, can anyone back me up? There is one spot that has a hole drilled, and thats where the wrist pin goes, thats it. here is a pic of the rod....
[IMG][/IMG]
see no hole
[IMG][/IMG]
see no hole
[IMG][/IMG]
no holes
[IMG][/IMG]
and the specs to the rods
Premium Forged 4340 steel
Reduced weight
Matched sets ±1 Gram
3D design 2PC forged
X-rayed
Sonic tested
Magnafluxed
Heat treated
Stress relived
Surfaces machined
Stroker clearanced
Rated to 650HP
ARP 3/8" cap bolts
Capable of handling high TURBO BOOST!
Fits Aftermarket Float Type Pistons (JE, CP, Wiseco, and etc.)
Old Jul 17, 2007 | 05:06 PM
B A N N E D
damn i love helpin people out, but my threads gets ignored !!!!!!!!!
Old Jul 17, 2007 | 09:55 PM
B A N N E D
****** bump
Old Jul 17, 2007 | 11:25 PM
Suck my DX's Avatar
Default Re: (DecentCivicZ6)
i wish i could help. but i would suggest you call the manufacturer and ask them ...i dont think anybody else would know better than the people who made the product
Old Jul 17, 2007 | 11:33 PM
B A N N E D
naw, what imasking, is do other brands, like Eagle, and all the others, do they all have an oil hole going right to the rod bearing like stock rods, I mean it has to, why would stock have an oil hole, and not aftermarket...just trying to make sure. thanks for the input.
Old Jul 18, 2007 | 08:15 AM
Bakeoff's Avatar
There is not a hole on the rod on purpose. You can also get some fairly high end bearings that don't have the groove down the middle. It's just the way they are. The rod if fine as well as the bearings.
If you think about it, if the rod had a hole in it to match up to the bearing's hole, the oil would just blow out the hole and wouldn't lubricate between the bearing and crank since there would be no pressure.
Old Jul 18, 2007 | 06:03 PM
NJIN BUILDR's Avatar
Default Re: Rod Bearing lubrication issue (DecentCivicZ6)
The hole in the stock rods is to spray oil on the piston and cylinder wall for cooling and lubrication.This also reduces pressure at the rod bearing slightly and causes a lot of oil to be spraying around in the cases.Typically aftermarket rods eliminate these holes for almost every make and model.
Old Jul 18, 2007 | 09:40 PM
B A N N E D
sweet thanks guys...just somthing i wanted to double check...ive had a good 6 people tell me thats normal now...again thanks
Old Jul 22, 2007 | 11:42 PM
quicksilver1689's Avatar
i ♥ snails
yeah your ready to rock
n/a_kong
Jul 2, 2010 06:52 AM
dj-t
Jul 2, 2009 08:48 AM
tdizz07
Oct 27, 2006 08:24 AM
Mad Cow Disease
Oct 2, 2003 01:55 PM
