Weird compression test
Old Jul 17, 2007 | 02:18 PM
allmotorslut's Avatar
Default Weird compression test
My motor got 700miles on it and i do a compression test and i got 270/240/210/240...the motor is brand new from a refresh (GSR with 82mm ctr pistons) oversized valve too.
the setup is not tune top notch, the plug is showhing thats is rich. The thing i want to understand is why i have one with 270 and the #3 210...last week i got 245 on each cylinder...so now i'm lost lol
thx for the help!
Old Jul 17, 2007 | 06:34 PM
slowcivic2k's Avatar
Default Re: Weird compression test (allmotorslut)
I hope you bored the hole to match the slug, because pistons are not exactly 82mm in diameter....
I also hope that you gapped the rings correctly...
Could also be caused by a crappy valve job.
I think you may have a inconsistency in the valve job or the bore.
Modified by slowcivic2k at 10:58 PM 7/17/2007
Old Jul 18, 2007 | 06:21 AM
4g hatch's Avatar
the #'s may even out with more miles. also may need to overlap the valves to get them to seat right
Old Jul 18, 2007 | 06:59 AM
Default Re: Weird compression test (slowcivic2k)
the bore job is perfect and the valve job too...i just find that weird because last week i have 245 in each cylinder and now i got difference.
Old Jul 18, 2007 | 12:49 PM
What was the piston to bore clearance of those pistons... I highly doubt it was perfect, and with a variation like that, I have no reason to believe that it is.
Old Jul 18, 2007 | 11:47 PM
yeah but for 650miles i've got 245 on each cylinder...if i had bad clearance of the bore, this problem was been there from the begining right?
Old Jul 19, 2007 | 11:06 AM
Not necessarly, if the bore was clearanced poorly, the pistons will simply beat against it and make the gap larger, and will not properly allow the rings to do their job.
How did the machinist perform the valve job? did he lap the valves to the seats? Or did he just throw them in here?
Are you showing any signs of leaks on the spark plugs?
Old Jul 19, 2007 | 12:20 PM
the oversize valve job is perfect, no leaking there, and my plug and black...he run rich, well in the air/fuel gauge, tomorrow the car will be tuned.
Old Jul 20, 2007 | 08:59 AM
200WHP@8200
Old Jul 22, 2007 | 11:40 PM
quicksilver1689's Avatar
i ♥ snails
wow ! now tell us your complete seutp
Old Jul 26, 2007 | 07:13 AM
200WHP@8200 on a mustang dyno
MODS
gsr block with 82mm CTR pistons
CTR head NO PORTING
CTR camshafts
ferrea oversize +1mm valve
supertech valvespring/retainer
AEM camgear
AEBS intake port match
dh-racing 71MM TB
450cc dsm injector
aem fuel rail
aem c.a.i.
custom 2 3/4 exhaust
F1 tri-y headers
fidanza flywheel
hondata S200
Modified by allmotorslut at 9:47 AM 7/27/2007
Old Jul 27, 2007 | 09:01 AM
Man the motor have a problem...the compression is now 250/240/170/210...i will do a leak down test asap
nemesis25
Jan 12, 2015 04:17 PM
@llmotorwhor3
Nov 26, 2006 07:43 AM
timisyourfriend
Jun 22, 2006 07:12 PM
bdicustoms
Aug 25, 2004 04:21 AM
Yosshaa
May 23, 2004 11:55 AM
