Subs, battery, or alternator
Old Jul 17, 2007 | 01:40 PM
Birdley42008's Avatar
Default Subs, battery, or alternator
I have a problem when I hook the power cable to the battery many different ways it seems that my 400w amp with 2 10'' subs draw to much power from either the battery or alternator and my car will make the starting effort but wont turn over accessories and vents will work. I have a 97 DX hatchback.
Old Jul 17, 2007 | 02:34 PM
Default Re: Subs, battery, or alternator (Birdley42008)
I was thinking a capacitor but i dont think its a problem with getting power to the amp cause without a capacitor you in theory should still be able to start your car not in my case where it wont start if i hook up the subs, even if the subs arent turned on.
Old Jul 17, 2007 | 04:32 PM
fcm's Avatar
fcm
Old Fart
Sounds like you have a connection problem, if the amp is not on it draws no current, make sure your batt. terminals are clean and tight, also check the batt. cable at the starter motor/solenoid. 94
Old Jul 17, 2007 | 05:08 PM
Default Re: Subs, battery, or alternator (fcm)
The bolts on the terminal were tightened completely but wont stay securely connected to the battery is there anyway to make a better connection by using something like a spacer on the battery? My car now without the subs hooked up still starts kinda rough and i know its because the terminal is not as tight around the battery, what can i do to make it stay on better aside from tightening a **** ton which has already been done?
Old Jul 20, 2007 | 01:36 PM
A new aftermarket terminal, a new 500 duralast battery, and some petroleum jelly did the job. : )
Old Jul 20, 2007 | 04:07 PM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Birdley42008 &raquo;</TD></TR><TR><TD CLASS="quote">A new aftermarket terminal, a new 500 duralast battery, and some petroleum jelly did the job. : )</TD></TR></TABLE> 94
dianam321
Oct 28, 2008 05:24 AM
SkIp_Civic_Ek6
Jan 30, 2008 08:11 PM
Midori Green
Nov 30, 2007 09:57 PM
ferby
Audio / Security / Video
Jun 11, 2005 08:16 AM
i
Nov 21, 2003 11:37 AM
