11.8:1 Compression D16a6 what to use for tuning??
Mild head build port and polish mild cam springs and retainers. Block is SRP 11.8:1 Pistons and cryotreated rods fully balanced. The crank was knife edged and polished. This is the stock motor on a 91 crx si. Also has your normal bolt ons.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slow96coupe »</TD></TR><TR><TD CLASS="quote">I would convert to obd1 and use either Chrome or Hondata</TD></TR></TABLE>
Crome ...
I do agree though OBD1 is a step up from the old tuning programs for obd0 system.
Crome ...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pee Wee »</TD></TR><TR><TD CLASS="quote">whatever the tuners in your area use
This is the ultimate answer.
If i had to chose though id go obd1 and use Neptune. Crome (obd1) or turboedit (obd0) are also good choices if you are on a budget. If you're not tuning it though I would talk to whoever is and see what they prefer.
</TD></TR></TABLE>This is the ultimate answer.
