How to remove An EG dash
Old Jul 17, 2007 | 10:52 AM
T Rick's Avatar
Default How to remove An EG dash
I GOT RID OF MY HATCH AND GOT A MOTORCYCLE SO I CANT TAKE NEW PICS SO....... I MADE ONE.
First off take the steering wheel off its not hard you only take out 2 star screws on the side of the wheel.
When those are out take out the airbag and unplug it.
When that is out then take out the large bolt in the middle.
Then the blinker switch and the windsheild wiper switch comes out but you have to unscrew 2 screws and take a flathead stick it here.
now take out the section where the cigarrette plug in is(4 screws 2 on top and 2 on the side)Take out the screw wen off
Then take out the glove box which is not hard there is like 4 screws.
You will need to take out the speed ometer.
Now on the top of the dash(middle) is that vent thing. pop that off with a flathead from the side. When off take out the screw(I think they are all 10 mm or maybe 12mm)
Now to take out the passenger air bag when the glove bx is out look under there and you will see 6 bolts that need to be taken out.
take out your stereo, unplug the wires on the driverside underdash fuse box.
Now work the dash board off and unscrew or unplug anything holding back.
now on both sides there are screws under the caps.
Modified by T Rick at 12:18 PM 7/17/2007 <U></U> <U></U> <U></U> <U></U> <U></U> <U></U> <U></U> <U></U> <U></U>
Modified by T Rick at 11:27 PM 10/21/2008
Old Jul 17, 2007 | 11:24 AM
Felliph3's Avatar
Sick writeup!! I was looking for one....Good job
PS:Nice sandals :-p
Old Jul 17, 2007 | 11:39 AM
MagnaniEG6's Avatar
Default Re: (Felliph3)
T Rick's Avatar
i new somebody would see those. i live in oregon and its pissin rain outside. well somebody needed help so put on my gals sandles and took a few snaps
Old Jul 17, 2007 | 11:50 AM
perseverance's Avatar
thx bro, as soon as i get some more money... i'm gonna go get a black interior from a salvage yard. hopefully this write up will help out. anyway u can give more info on taking off the steering wheel?
Old Jul 17, 2007 | 12:15 PM
bara6075's Avatar
Default Re: How to remove An EG dash (T Rick)
Old Jul 17, 2007 | 12:44 PM
instructor74's Avatar
Default Re: How to remove An EG dash (bara6075)
THIS IS HUGE before you unhook the air bag plugs you must disconnect the neg battery terminal and wait 5 mins or longer. It is now safe to unplug the air bags make sure you install the safety jumper to keep the air bag from being set off be accident.
Old Jul 17, 2007 | 12:49 PM
T Rick's Avatar
Default Re: How to remove An EG dash (instructor74)
o ya forgot you must unhook your battery and to take off the steering wheel there are side plastic peices that come off and there are star screws on each side that you unscrew when the are out take out the center of our steering wheel(airbag) unhook the plug and the take out the huge bolt on your steering wheel(Not hard to miss) Then its off
Old Jul 17, 2007 | 12:53 PM
Felliph3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by instructor74 &raquo;</TD></TR><TR><TD CLASS="quote">THIS IS HUGE before you unhook the air bag plugs you must disconnect the neg battery terminal and wait 5 mins or longer. It is now safe to unplug the air bags make sure you install the safety jumper to keep the air bag from being set off be accident.</TD></TR></TABLE>
Damn it, i was going to type that too but my internet went down and when it went back up i forgot. But yea be very careful or it will activate on your *** and knock you out for like 5 minutes.
Old Jul 17, 2007 | 01:11 PM
jus_spooln_wicha's Avatar
Default Re: How to remove An EG dash (Felliph3)
is that a jdm climate control?
a href="http://photobucket.com" target="_blank"&gt;Name:  climatecontorl.jpg
Size:  26.7 KB&lt;/a&gt;
Old Jul 17, 2007 | 01:34 PM
methos713's Avatar
Default Re: How to remove An EG dash (jus_spooln_wicha)
Should sticky this. By the way, how what does the safety jumper look like? Can't you just unplug the srs plug underneath the dash?
Old Jul 17, 2007 | 02:45 PM
1.8L_allmotormilitia's Avatar
get a 4 puck clutch and some motor mounts and launch ! ur dash will come right off ! b carefull might land in ur lap !
Old Jul 17, 2007 | 04:41 PM
Default Re: How to remove An EG dash (methos713)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by methos713 &raquo;</TD></TR><TR><TD CLASS="quote">Should sticky this. By the way, how what does the safety jumper look like? Can't you just unplug the srs plug underneath the dash?</TD></TR></TABLE>
It should be attached to the access panel on the bottom of the steering wheel . open that panel disconnect the yellow plug remove the red plug from the panel and insert into the air bag plug
Old Jul 17, 2007 | 05:18 PM
methos713's Avatar
didn't know there was a red plug there...hummm, I'll go check. Thanks.
Old Jul 17, 2007 | 06:50 PM
TTacous's Avatar
Thanks for the write up. Now I don't have to break things taking out my dash
Old Jul 17, 2007 | 08:23 PM
akunamatta's Avatar
* B A N N E D *
FYI: you do not have to remove the guage cluster and bezel in order to remove dash.
Old Nov 21, 2007 | 02:52 PM
ydoubleonie's Avatar
coooll... but the pics are down. can you put em back up?
Old Nov 21, 2007 | 02:58 PM
Syndacate's Avatar
I added it to the FAQ, get your pictures working.
If you need somebody to get 'em hosted for ya PM me.
Old Dec 16, 2007 | 12:03 PM
srg's Avatar
srg
pics don't work can someone correct links?
Old Jan 20, 2008 | 08:32 PM
StoryBookSin's Avatar
nice write up THx
Old Jan 20, 2008 | 08:36 PM
pemd5555's Avatar
Default Re: (StoryBookSin)
nice write up bump thanks
Old Feb 16, 2008 | 06:42 PM
ajaxK1's Avatar
Default Re: (pemd5555)
someone correct the pic links please.....
Old Feb 16, 2008 | 06:46 PM
BlueIntegraBoy's Avatar
Default Re: (ajaxK1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ajaxK1 &raquo;</TD></TR><TR><TD CLASS="quote">someone correct the pic links please.....</TD></TR></TABLE>
Old Jun 24, 2008 | 01:00 PM
denraweb's Avatar
Default Re: (BlueIntegraBoy)
Can someone fix the pics? This would be a great write up if there were working pics...
Old Sep 29, 2008 | 04:53 PM
iluvmyEJ1's Avatar
hey can you redo your pic?? it would help out alot! thanks.
