What camshafts??
Old Jul 17, 2007 | 10:13 AM
T3k C's Avatar
Default What camshafts??
Hey, I'm in need of advice everyone. I have 00 itr w/ crower dual valve springs, ti retainers, manley oversized valves. Block is stock w/ bolts on. I can't figure out a good set of cams. My R is somewhat daily driver so a set of street cams is a must. thanks
Old Jul 17, 2007 | 10:15 AM
Dave_B's Avatar
Why would you have done all that valvetrain work, with no internal mods and no cams?
Old Jul 17, 2007 | 10:21 AM
JjuuN R's Avatar
Default Re: (Dave_B)
Right Dave? lol...
Depends on how much power you want to make and what your compression is or will be. This will just be another... well I run this and I have this yadda yadda yadda thread.
Old Jul 17, 2007 | 10:24 AM
T3k C's Avatar
Well i'm looking for a set of cams before i install the head. Are you saying that i won't have any benefits of having a built head on stock block at all???
Old Jul 17, 2007 | 10:28 AM
Relic1's Avatar
cams depend a lot on compression. raising it will result in more power and different cam profiles.
Stock compression... M22s are what I'm looking at.
Old Jul 17, 2007 | 12:52 PM
Dave_B's Avatar
Default Re: (T3k C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T3k C &raquo;</TD></TR><TR><TD CLASS="quote">Well i'm looking for a set of cams before i install the head. Are you saying that i won't have any benefits of having a built head on stock block at all???</TD></TR></TABLE>
Most of your power will always be made in the head... That said, you need supporting mods too.
What I'm getting at is this... You want power? You gotta do the head. You want to do the head, you gotta do cams, you want good power, you gotta use radical cams, you want to use radical cams, it's pointless without higher CR's.
See where I'm going with this? It's a snowball affect...
Old Jul 17, 2007 | 12:57 PM
RTW DC2R's Avatar
if you are daily driving this car and end up getting big cams, be careful of retainer wear. since the head isnt installed yet, I would put the stock retainers back in since its a daily driver.
g23cg5
Nov 15, 2013 04:58 AM
shiftmx179
12
Jan 28, 2011 01:12 AM
slowpokecivic
Nov 10, 2006 03:07 PM
CivicVX94
Jun 13, 2006 03:08 PM
The Destroyer
12
May 30, 2006 02:57 PM
