eg hatch front on sedan
Hi,
I've been searching around but haven't been able to find anything on the topic. I want to know if the eg hatch front end would fit on the eh sedan? Would they all line up properly?
Thanks
Thanks
no.. you need to customize your fender lines to match an eg hatch bumper
check this pic, my friend's eg sedan eg hatch front bumper conversion
encircled on eg hatch bumper is the pattern for your fenders to match its width..
hth
hth
almost forgot, if you are planning to retain the stock eg sedan corner lights it will be fine.. but if you will use eg hatch corner lights, you need to customize again the fender that will catch the back end portion of the light
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95ProjectEJ1 »</TD></TR><TR><TD CLASS="quote">Very clean sedan... nice front end "conversion"
</TD></TR></TABLE>yeah, indeed a very good conversion on that!
things you need for a coupe/hatchback front-end conversion for your sedan:
coupe/hatchback fenders
coupe/hatchback corner lens
coupe/hatchback front bumper
aftermarket lip or stock lip for a coupe/hatchback
<FONT SIZE="3">***NO CUTTING, NO WELDING...>>><FONT COLOR="red">JUST DIRECT BOLT-ON</FONT>***</FONT>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eg6sir-s »</TD></TR><TR><TD CLASS="quote">things you need for a coupe/hatchback front-end conversion for your sedan:
<FONT SIZE="3">***NO CUTTING, NO WELDING...>>><FONT COLOR="red">JUST DIRECT BOLT-ON</FONT>***</FONT></TD></TR></TABLE>
this is good. but its too much work for just wanting the hatch front, so i cut corners.
here's another shot
here's another shot
mj91ef9
Jun 10, 2009 01:48 PM
