Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
How do you replace the headlight assembly on a 2003 Civic EX?
Old Jul 16, 2007 | 11:43 PM
Corndogg0az's Avatar
Default How do you replace the headlight assembly on a 2003 Civic EX?
How do you replace the headlight assembly on a 2003 Civic EX? Do you have to remove the bumper cover? It looks like a real pain.
Old Jul 17, 2007 | 04:12 AM
InanimateCarbonRod's Avatar
Default Re: How do you replace the headlight assembly on a 2003 Civic EX? (Corndogg0az)
Yep, you have to remove the bumper cover. You'll need an extension to get to some of the bolts holding the headlight/headlight bracket. Other than that it's pretty straightforward.
Old Jul 17, 2007 | 03:23 PM
blackKready's Avatar
Default Re: How do you replace the headlight assembly on a 2003 Civic EX? (InanimateCarbonRod)
bolt on each side going up into fender. few pop outs under the front bumper as well as 2 phillips screws. half dozen or so pop outs by hood latch. than grab the front bumper right in front of front wheel , and pull straight out , ittl pop out. same on other side , than pull front wards and it falls off. 10mm bolts holding headlight assembly to car. 2 on top , 2 under.
silron
Jun 27, 2012 10:44 AM
ergot
May 3, 2005 02:22 PM
CivicEXGuy
Jul 17, 2004 11:56 AM
specie
Jan 23, 2004 12:23 PM
4th gen hatch
Mar 14, 2003 09:10 PM
