No idle
Old Jul 16, 2007 | 06:44 PM
InvaderTrax's Avatar
Default No idle
All started the other day. Check engine light came up. Code 14 - IAC motor. Pulled it and cleaned it up, no good. Got a used one, tried it, no good. Plug has voltage when car is in ON position. Idle is low when cold, stalls when warm. I don't have "test harness A" so I can't go any further than this. If I had a spare ECU, I'd try that just to see if I can rule anything out. I had the ingenious idea of making a vacuum leak by disconnecting my IABs and now it idles when warm (because all the IAC does is make a controlled vacuum leak anyway), so it's at least drivable. Any other ideas?
Old Jul 16, 2007 | 06:47 PM
bluedlude's Avatar
Default Re: No idle (InvaderTrax)
i would try a different ECU if you replaced the IAC and its still giving you the same problem.
Old Jul 16, 2007 | 06:51 PM
SteveoBA8's Avatar
I just looked over a flow chart and instead of using their Honda test harness, couldnt you just use a piece of wire to jump the two terminals A9 and A26 and listen for the iac to click?
Old Jul 16, 2007 | 07:13 PM
If I can figure out which pins they are. I'm just kinda searching for ideas right now. I don't intend on testing anything till tomorrow or so. I'll also ask around the shop for ideas
Old Jul 16, 2007 | 07:20 PM
SteveoBA8's Avatar
Default Re: (InvaderTrax)
There is a good pic of the ECU A/B/C connectors in this thread. https://honda-tech.com/zerothread?id=1004852
Posted by CHK4TIX
honcrf150
Jan 1, 2013 04:03 PM
gorsey
Aug 22, 2011 10:45 AM
91dxhatch
Jan 4, 2007 11:46 AM
allmotorsi04
May 11, 2004 04:49 PM
CRXhf90
Oct 1, 2002 01:58 PM
