Adjustable shift linkage ... help
Old Jul 16, 2007 | 05:58 PM
iMPoRT GeeK's Avatar
Default Adjustable shift linkage ... help
Ok I install an adjustable shift linkage on my 4dr EF with GSR & cable CTR tranny. NOW I ONLY have 3rd and 4th gear.. what gives??? Adjustable Shift linkage no good??? what shift linkage should I be running?
Let me know...
Thanks
Old Jul 16, 2007 | 07:23 PM
builthatch's Avatar
MiG-21 superfan
Default Re: Adjustable shift linkage ... help (iMPoRT GeeK)
adjustable shift linkage! hmm, never heard of that...
you have some sort of conversion piece to get that tranny working w/ cable i guess, huh?
Old Jul 16, 2007 | 08:33 PM
Default Re: Adjustable shift linkage ... help (builthatch)
conversion piece? what you talking about its a B16 CTR Y1 w/ LSD ARE cable. i dont need any pieces...???
Old Jul 16, 2007 | 08:49 PM
builthatch's Avatar
MiG-21 superfan
in the first post you said 'cable ctr tranny'
there is no such thing as all civic type r transmissions were hydraulic.
Old Jul 16, 2007 | 09:05 PM
ok its a JDM B16 Y1 Cable Tranny with LSD.... ?
Old Jul 16, 2007 | 09:15 PM
builthatch's Avatar
MiG-21 superfan
right.
so back to the linkage, is it a defunct piece? i'm unaware of adjustable linkages.
i'd say if it is adjustable and is indeed for the dohc into ef swap, lengthen it in increments and shift through the gears with the car not running to assure it's engaging. maybe get someone to shift while the car is up on jackstands and see what it's NOT doing properly.
are you not able to get into reverse either?
Euphorex
Transmission & Drivetrain
May 22, 2013 08:38 PM
EF9_RIDER37
11
Nov 11, 2009 11:34 AM
leem23vtec
Oct 2, 2009 11:17 PM
DroopyHatch
Feb 20, 2005 11:22 PM
Skible
Apr 23, 2004 09:45 AM
