dont know much about brakes, little help.
Old Jul 16, 2007 | 05:48 PM
bluedlude's Avatar
Default dont know much about brakes, little help.
aight... long story short, my caliper was seized up on me. so real quick, i disconnected the line and used an air compressor to pop out the caliper piston. then i pressed it back in and it wasnt seized up anymore. do i need to bleed my brakes now? just that one caliper right? the rest should still be OK, correct me if im wrong.
Old Jul 16, 2007 | 06:01 PM
98vtec's Avatar
moderator emeritus
Default Re: dont know much about brakes, little help. (bluedlude)
you'll need to bleed the whole system since it is afterall a system. Each caliper doesnt have its own feed. It all eventually tees into one. There is a certain order you need to do them in, if you dont have a manual i guess i could dig it up for you.
Old Jul 16, 2007 | 06:05 PM
bluedlude's Avatar
Default Re: dont know much about brakes, little help. (98vtec)
but there is a bleeder screw on each individual caliper. and the fluid never stopped running out of the brake line while i did what i had to do. and ive got a manual im just trying to avoid bleeding the whole system.
Old Jul 16, 2007 | 06:08 PM
bluedlude's Avatar
i guess its not too hard, im just a lazy ***. thanks blake.,
Old Jul 16, 2007 | 06:09 PM
98vtec's Avatar
moderator emeritus
quit being a lazy ***.
if you wanna do something fun, install some extended wheel studs on a lude. thats a PITA.
Old Jul 16, 2007 | 06:14 PM
bluedlude's Avatar
dude, my car still isnt back on the road from when i had to change my clutch. its just one thing after the other. im about two days out right now, and i dont even want to touch that car right now.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">quit being a lazy ***.
if you wanna do something fun, install some extended wheel studs on a lude. thats a PITA.</TD></TR></TABLE>
dont you just bring your hub to a shop and have them press in some new ones?
Old Jul 16, 2007 | 06:21 PM
SteveoBA8's Avatar
Bleed the Pass rear 1st
Then the Driver rear
Then Passenger front
Driver front.
Old Jul 16, 2007 | 06:24 PM
bluedlude's Avatar
Default Re: dont know much about brakes, little help. (SteveoBA8)
according to the helmes, its drivers front, passenger front, passenger rear then drivers rear.
Old Jul 16, 2007 | 06:29 PM
SteveoBA8's Avatar
Opps I couldnt remember if it was furthest away or not. Sorry. Do what the helms says.
Old Jul 16, 2007 | 06:33 PM
98vtec's Avatar
moderator emeritus
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bluedlude &raquo;</TD></TR><TR><TD CLASS="quote">dude, my car still isnt back on the road from when i had to change my clutch. its just one thing after the other. im about two days out right now, and i dont even want to touch that car right now.
dont you just bring your hub to a shop and have them press in some new ones?</TD></TR></TABLE>
ha....no. well...i guess you could do that, but thats more money spent and then you gotta worry about you wheel bearing....expletive that, lol.
on the fronts you have to grind maybe 1/8th - 1/4" off the hub then you have to grind the heads of the stud down so you can slide it into the hub. It's ALOT of grinding, lol.
hour and half for one of the fronts, about 45 minutes of it was grinding, lol.
Old Jul 16, 2007 | 09:30 PM
Hawkze_2.3's Avatar
Yeah, you most likely wil have to bleed all the brakes. You could bleed that one caliper and then if you still have good pressure you' be fine....but it just depends.
Was it the same as on a 4th gen? I know I had fun with mine
Old Jul 16, 2007 | 09:40 PM
98vtec's Avatar
moderator emeritus
Default Re: dont know much about brakes, little help. (Hawkze_2.3)
yea, rears were cake...fronts were a bitch and had to be ground down. My dremel was pissed.
Old Jul 16, 2007 | 09:49 PM
Hawkze_2.3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">yea, rears were cake...fronts were a bitch and had to be ground down. My dremel was pissed.</TD></TR></TABLE>
Sounds just like mine
Old Jul 16, 2007 | 09:57 PM
98vtec's Avatar
moderator emeritus
i had to put on gloves cuz it was getting so hot, lol. I'd give it a break and put it in front of a fan at low speed for like 2 minutes then go back to grinding. I'm suprised nothing melted.
jdmboy69
Apr 2, 2014 08:39 PM
roadsqueegy95
Mar 14, 2009 09:21 PM
blink3665
May 22, 2006 09:07 AM
gezer
Oct 12, 2004 11:18 AM
ScootinIntegra
Oct 14, 2003 03:41 AM
