left turn signal wont work.
Old Jul 16, 2007 | 05:25 PM
preludeh22a1's Avatar
Default left turn signal wont work.
my left signal wont wotk, inside the gauge its not blinking but you can hear it clicks and fast, I checked the ground the fuse and the bulb and it was ok. sometimes it work, but most of the it wont. i tried to search but i cant find some topics about it. please help.thanx in advance.
its kinda embarassing to use hand signal anymore.
Old Jul 16, 2007 | 05:38 PM
prelude1897's Avatar
Default Re: left turn signal wont work. (preludeh22a1)
are you sure the bulb is pushed in all the way? Try a new bulb and see what happens cause maybe the filiment inside just taps each time you hit a bump making it work.
Old Jul 16, 2007 | 10:51 PM
Default Re: left turn signal wont work. (prelude1897)
oh thanx man.. ill check it. if its all poush all the way in, what should be next to check? i want to fix this badly.
Old Jul 17, 2007 | 12:01 AM
prelude_93vtec's Avatar
ya i had teh same problem when my light clicked fast. usually that means bulbs are bad but my problem was that the little metal piece inside the conector was pushed in all the way thus not touching the bulb so p pried it up a bit and problem solved
Old Jul 17, 2007 | 12:27 AM
Default Re: left turn signal wont work. (prelude_93vtec)
thnx good info, ill check it in the morning.
Old Jul 17, 2007 | 06:28 AM
SKDRCR's Avatar
Hook a test light up to the socket and see if you're getting power to it.
Uncle Ben's
Jul 8, 2007 12:08 PM
DynastyRacer22
Honda Civic (2001 - 2005)
May 20, 2007 08:39 PM
rkrone
14
Aug 26, 2006 06:38 AM
ferio 95
Mar 10, 2004 07:48 PM
