Help with Rack and Pinion Rebuild
I'm upgrading from a vented P/S rack to a manual Quaife Rack and I've run into a small problem - there is a clip that goes on the pinion, that locks the pinion bearing into place. I cannot for the life of me find a replacement for this clip nor how to even remove it. Any help or insight would be greatly appreciated. I need to either get this clip out or purchase a new one to hold the new pinion bearing onto the Quaife pinion.
Again I’m in with the guess lol. How about a big old pair of visegrips on the humped (yes I said humped) part, it should bulge out the rest and once it’s off just bend it back to shape. That’s all I got, that **** looks beefy though.
I think I tried that method, the problem with that is that the piece is so narrow with the bearing right underneath that I have no hope in getting a grip on it.
Doubtful as it slides into position in a shallow grove directly on the top of the bearing. I could try it though, but I'm rather sure it would snap the clip. Now if I had say...a 35mm pipe I could use it to help me push the bearing and pinion into the housing without the bearing sliding.
my factory manual, as well as the Autozone repair info, says this:
"The pinion bearing assembly cannot be removed if it shows signs of wear. If the bearing is to be replaced, replace as an assembly."
http://autozone.com/az/cds/en_...s.htm
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dr_latino999 »</TD></TR><TR><TD CLASS="quote">Any insight folks?</TD></TR></TABLE>
why are you bothering with that odd clip? youre going to be replacing the pinion gear anyway, and be using a new bearing. so why not just buy a new retaining ring and go ahead with the install?
http://www.slhondaparts.com/br...4-003
are you trying to put the quaife rack into your power steering rack????
is that even possible?
its supposed to only go into the DX manual rack.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by abnaasefmb »</TD></TR><TR><TD CLASS="quote">cut the ****** off and tack weld the bearing back in place</TD></TR></TABLE>
Not a bad idea,
http://www.hondaautomotivepart...NENTS
But it looks liek the bearing is 15 bucks and a new clip 2
Not a bad idea,
...esteban
Jul 19, 2016 09:35 PM
dr_latino999
17
Jul 21, 2007 01:02 PM
eda6
Nov 25, 2006 10:27 AM
