Help on remote Start...
I wanted to install a remote start into my manual trans car and need help on some of the wires location. The wires are...(Bypass Output, and the Oil sensor Input/Alternator Input). These wires are identified in my alarm manual..I wanted to know where does these wires connect to...I have a 95 Accord by the way.
I don't know the alarm brand..but i bought it from ebay..basically..I just need to know where those two wires connected to..but isn't all remote start the same (manual car)...please anyone...who has done a remote start for a manual tranny..reply..
Bypass Out probably goes to an immobilizer bypass module, which you won't need since you have a '95.
Oil Sensor/Alternator is probably what the knockoff manufacturer is calling their tach signal, which you can tap at the distributor. Wiring colors can be found here: http://www.bulldogsecurity.com
Now, someone please post the pic of the Civic and the broken brick wall...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord23 »</TD></TR><TR><TD CLASS="quote">I don't know the alarm brand..but i bought it from ebay..basically..I just need to know where those two wires connected to..but isn't all remote start the same (manual car)...please anyone...who has done a remote start for a manual tranny..reply..</TD></TR></TABLE> Then just link us to the eBay vender.
Ditto what B18C_EJ8 said. Unless the remote start is made for a manual transmission you should not be installing it, someone will post the pix and you will see why, and before you come back and tell us how you never leave it in gear and you always use the "E" brake, think about this, the day you or someone else forgets, insurance does not pay out, under any circumstances, for any damage or liability you may incur.
94
94
Okay..Thanks b18c..another question i have is..which wire in the ignition will be strong enough to hold a 30amp volt wire...remember my car is a 95 accord...FYI FCM..here is the link to it..
http://cgi.ebay.com/ebaymotors...QrdZ1
one more thing..i got the remote start work but when it got started..i tried to step on the brake pedal but the remote doesn't die..usually it turn off...what did i do wrong?...any info..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord23 »</TD></TR><TR><TD CLASS="quote">Okay..Thanks b18c..another question i have is..which wire in the ignition will be strong enough to hold a 30amp volt wire...remember my car is a 95 accord...FYI FCM..here is the link to it..
http://cgi.ebay.com/ebaymotors...QrdZ1</TD></TR></TABLE>
Oh jeez.... I'm sure I'm not the only one that's not going to help you anymore...
I don't want my name associated with helping you install that piece of ****, especially when it sets your car on fire...
Good luck...
Good luck...
Oh jezzzzzzzz, one of them, no name, noname alarm/starters, no info available.
Can you copy and paste the wiring diagram for us?
I get a little worried when I see stuff like this...
" For the manual transmission in order to avoid for your car to jump on remote start you will have to BYPASS the clutch."
94
94
I did bypass the clutch...but for some reason when my remote start comes on..and pressing the brake..the car doesn't turn off..any help..i'm sure this isall alike as any other car remote u guys install it before...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord23 »</TD></TR><TR><TD CLASS="quote">I did bypass the clutch...but for some reason when my remote start comes on..and pressing the brake..the car doesn't turn off..any help..i'm sure this isall alike as any other car remote u guys install it before...</TD></TR></TABLE> Actually no, I don't install remote starts on manual transmission cars unless it is made for manual transmission cars, it must have some kind of fail safe, to prevent remote starting in gear.
There is no reason to install an auto transmission remote start in a car when there are so many that are made for manual transmissions.
94
94
doesn't the brake wire get hook up to the wire above the brake pedal..or is it hook up to the ignition wire..because i just hook it up to the brake pedal wire..and what wire in the ignition is strong enough to hold a 30 amp wire coming from the remote start..or do u have to hook it up to the battery...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">
Good luck...
Any more votes for lock?
Good luck...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B18C_EJ8 »</TD></TR><TR><TD CLASS="quote">Now, someone please post the pic of the Civic and the broken brick wall...
This?
</TD></TR></TABLE>This?
I need help on wiring..not luck on how my car may end up...FYI..I always park in neutral and with my e brake on..so it shouldn't be a problem for my car to jump like the civic in the pix did...so any serious help????
From: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Are you sure you hooked it up to the right brake wire. I like the part that says you need to bypass the clutch so the car does not jump. rofl. What kind of relay for that.
That there is an Integra.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord23 »</TD></TR><TR><TD CLASS="quote">I need help on wiring..not luck on how my car may end up...FYI..</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accord23 »</TD></TR><TR><TD CLASS="quote">I always park in neutral and with my e brake on..</TD></TR></TABLE>
You should always park in gear and not rely on the ebrake.
LOCK FYI
LOCK FYI
owneyboy
Jun 4, 2011 06:42 PM
