What is wrong here?
Old Jul 15, 2007 | 02:22 PM
zeta's Avatar
Default What is wrong here?
Yesterday I got an message from a friend about 2 cars with BC3+ cams and camgears had broken off their timing belt. Since I also have that combination he recommend me too check it out.
Here is what I found when i removed the valve cover
And, the solution
But, what is wrong. Is there possible something is done wrong when it was installed, or is it the cams and cam gears?
Luckily my car haven't been used as much as the 2 other cars. I reckon the same thing would happen with at some point..
Old Jul 15, 2007 | 03:28 PM
Cheeze's Avatar
Default Re: What is wrong here? (zeta)
Damn..I have the same setup..Think I will have to look at mines as well..Err!
Old Jul 15, 2007 | 10:37 PM
Circuit Star-29's Avatar
Default Re: What is wrong here? (Cheeze)
I've seen this before... Its just something that happens with aftermarket cams. Your solution was the same thing that everyone has done, that I've witnessed.
Old Jul 16, 2007 | 02:40 PM
gsr dood's Avatar
Default Re: What is wrong here? (Circuit Star-29)
i got this wen i installed my skunk 2 adj. cam gears, i think it was just the plastic not being installed properly.
Old Feb 28, 2008 | 05:24 PM
Cidone's Avatar
Default Re: What is wrong here? (gsr dood)
ive seen this a couple times.. when ive seen it its been due to time and heat changing the mold and causes them to rub up on the cam ear or the water pump on older acura CLs with 4 bangers in them.. i see it almost every other time i do a timing belt at acura.. im a tech there....
Old Feb 28, 2008 | 06:49 PM
heel_touge's Avatar
Default Re: What is wrong here? (Cidone)
my first thought was the red liquid gasket and not honda-bond hahaha.
vttitan18
Jun 5, 2008 05:22 AM
tacorunner87
May 25, 2008 09:57 AM
warrick
Jul 11, 2004 01:42 PM
acatak
Jan 28, 2003 05:29 PM
