distributor timing
Old Jul 15, 2007 | 01:11 PM
freshly boosted DOHC ZC's Avatar
Default distributor timing
if the distro timing is 180 degrees off would that affect spark?
Old Jul 15, 2007 | 01:37 PM
hatchling37's Avatar
Default Re: distributor timing (freshly boosted DOHC ZC)
yes
edit: <U>If</U>you could get it to line up with your cam, it wouldn't effect spark, but your firing order would be fucked up, obviously.
Old Jul 15, 2007 | 01:56 PM
RACEPAK's Avatar
Default Re: distributor timing (hatchling37)
bump for more info.
what will happan if the part that goes into the camshaft wont be aligned proparly like OEM (180deg off) from the shaft/rotor?
Old Jul 15, 2007 | 03:46 PM
Default Re: distributor timing (RACEPAK)
well just figured out my problem and it was 180 off. if it was 180 off it just keeps cranking over and over....but now i have a little rough idle and think it needs to be retuned
Old Jul 15, 2007 | 03:47 PM
slowcivic2k's Avatar
It's not possible, unless you put the dizzy in, and then put the cap over it, which would break it, the key in the intake cam is offset to one side, preventing this from happening, if it does not go in, it's not aligned right, turn it 180 degrees and it will fall in.
Old Jul 15, 2007 | 11:57 PM
bitek's Avatar
if ur goin to retard the timing from the distributor.. is it going to the IM or going to the exhaust manifold?
Old Jul 16, 2007 | 12:42 PM
Default Re: (bitek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bitek &raquo;</TD></TR><TR><TD CLASS="quote">if ur goin to retard the timing from the distributor.. is it going to the IM or going to the exhaust manifold?</TD></TR></TABLE>
You obviously don't know what your talking about, so don't confuse people.
Old Jul 25, 2007 | 10:25 PM
bitek's Avatar
^ what im asking is adjusting the timing from the distributor... retard and advance... going from where to where...
dont quote if u don't know the answer....lol
Old Jul 26, 2007 | 01:47 PM
Default Re: (bitek)
I do know the answer, and you should state your question correctly.
Do I turn my distributor clockwise to advance timing?
No, counterclockwise for advance, clockwise for retard.
foxyride22
Nov 23, 2013 12:01 AM
azzurribaggio
Jun 26, 2009 09:25 PM
98r410
Jan 23, 2007 05:16 AM
GaRn
Feb 5, 2006 07:10 PM
mrlover
Dec 10, 2005 01:19 PM
