Rear sway bar on DX, Si LCA's needed?
Old Jul 15, 2007 | 09:20 AM
hondacivic90zc's Avatar
Default Need Help!! Quick Question!!!
because my crx dx's didnt come with a rear sway bar what do i need to install one?
Do i need si rear control arms or can i use my dx control arms?
Old Jul 15, 2007 | 03:07 PM
Default Re: Need Help!! Quick Question!!! (iandavis90)
there isnt anybody out there that can help me.
Old Jul 15, 2007 | 03:37 PM
JustAnotherRex's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iandavis90 &raquo;</TD></TR><TR><TD CLASS="quote">there isnt anybody out there that can help me. </TD></TR></TABLE>
No, no one has ever done this before.
As a matter of fact, there is not an excellent article on the same topic over at http://www.crxcommunity.org
Or any good installs on here either.
Good luck with the welder.
Old Jul 15, 2007 | 03:52 PM
darsh39's Avatar
i suppose its a BIG no ....
Old Jul 15, 2007 | 09:59 PM
Default Re: (darsh39)
well i must say i love the sarcasm but you didnt answer my question.
Old Jul 16, 2007 | 08:45 AM
sircrxracer's Avatar
Pretty sure you need the LCA's and the sway bar brackets and sway bar. HTH's Rob
Old Jul 16, 2007 | 10:29 AM
http://crxcommunity.com/viewtopic.php?t=4944
Old Jul 16, 2007 | 10:30 AM
cr-x-91's Avatar
you can buy a kit that comes with the brakets and new mountin locations,i would just get some si rear lca.
Old Jul 16, 2007 | 10:32 AM
CRX Toad's Avatar
http://www.jegs.com/webapp/wcs...k=all
Searching on this topic would have given you faster results this has been covered a lot.
Old Jul 16, 2007 | 11:40 AM
crxfreak1117's Avatar
Default Re: (CRX Toad)
yes u do need the lca's i did the full rear disks/suspention and the sway bar mounts on the lca..
Modified by crxfreak1117 at 12:54 PM 7/16/2007
Old Jul 16, 2007 | 11:53 AM
Default Re: (crxfreak1117)
thanks for the help
Old Jul 16, 2007 | 12:17 PM
HBK's Avatar
HBK
Default Re: (iandavis90)
The body on DXs do NOT have the mounting points for the rear sway bar. You have to get the Suspension techniques sway bar that elimates that, and rear Si Lcas.
Good luck.
Old Jul 16, 2007 | 12:37 PM
VtecSyndrome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxfreak1117 &raquo;</TD></TR><TR><TD CLASS="quote">yes u do need the lca's i did the full rear disks/suspention and the sway bar mounts on the lca..
Modified by crxfreak1117 at 12:54 PM 7/16/2007</TD></TR></TABLE>
x2
crazy thing is some DXs come with the sway bar mount holes already threaded like the Si's even though you still need th LCAs. not sure why some DXs have the nuts welded in and others don't? only seen it like that on a few HBs though, not any CRX DXs (including mine)
griffinjr123
Suspension & Brakes
Nov 16, 2009 02:53 PM
crxsleeper210
Suspension & Brakes
May 4, 2006 01:27 PM
jtl
16
Apr 12, 2004 07:43 AM
jtl
Apr 1, 2004 04:24 PM
TheShocker
Oct 16, 2001 10:39 AM
