main and rod bearings
Old Jul 15, 2007 | 06:53 AM
ELPITUDO's Avatar
Default main and rod bearings
hey, whats up, i have a question, i'm rebuilding my motor a b18c and i need to know if is true that the main and rod bearings have a color code to install them. if anyone knows please reply. thanx
Old Jul 15, 2007 | 07:47 AM
b19coupe's Avatar
Default Re: main and rod bearings (ELPITUDO)
It's true. OEM bearings are color coded.
I prefer pink
Old Jul 15, 2007 | 11:23 AM
zerovandez's Avatar
i love the pink. it's loose enuf for the lube to get in, and tight enuf to have it feel real smooth......
Old Jul 15, 2007 | 11:37 PM
smileycvc's Avatar
Default Re: (zerovandez)
^^^Great post. seriously I laughed alot.
Old Jul 16, 2007 | 11:49 AM
zerovandez's Avatar
^^Why did you laugh? I use the pinks in my motor.
Old Jul 16, 2007 | 03:42 PM
Sam92Teg's Avatar
Honda bearings are color coded for different sizes, and if you search, you will find a thead that lists all the colors and sizes. Don't listen to someone telling you to run a certain size bearing, unless the clearances are checked afterward to see if they are within specs. They might fall within specs on their engine, but might not in yours.
Machine shops can measure and install the proper size bearings for a nominal fee. But, you can also use the codes on the block, crank, and rods to determine the OEM bearing size. If you have measuring tools at home, like a micrometer and bore gauge, you can also measure that way for bearing sizes. After you have your bearings installed with what should be the right size, you can then use plastigauge as a final check to see if they fall within specs. Good luck.
=-JDM-EG-=
Nov 28, 2010 09:54 PM
H22Luda720
Apr 5, 2006 05:27 PM
9295EJ-t
Jan 28, 2006 07:09 AM
TurboTeG4
Apr 25, 2004 05:59 PM
philafelman
28
Sep 8, 2003 06:45 PM
