99-00 si rear discs brake fit a crx?
if you plan on swapping out your drums for rear disc calipers, the 99-00 si trailing arms , along with the brakes will fit a crx (make sure you get the brake hoses! the drum lines won't work). 88-00 si & 90-00 teg rear disc brakes & trailing arms all interchange and share the same 9.4" rear rotor. you'll need source e-brake cables from a crx si. i also advise you to update your valve proportioner (from a car w/ non-abs rear disc).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roastbeefrichie »</TD></TR><TR><TD CLASS="quote">if you plan on swapping out your drums for rear disc calipers, the 99-00 si trailing arms , along with the brakes will fit a crx (make sure you get the brake hoses! the drum lines won't work). 88-00 si & 90-00 teg rear disc brakes & trailing arms all interchange and share the same 9.4" rear rotor. you'll need source e-brake cables from a crx si. i also advise you to update your valve proportioner (from a car w/ non-abs rear disc).
ok thanks
</TD></TR></TABLE>ok thanks
*Boostwerks*
Apr 26, 2007 10:25 AM
JSJ EG6
Mar 9, 2003 07:46 PM
