problem regarding to setting the timing on CRX
Old Jul 14, 2007 | 09:05 PM
kekekekevin's Avatar
Default problem regarding to setting the timing on CRX
I have a 88 CRX SI. I am trying to set the timing. I follow the steps on ALLDATA. I can find the 2-pin cable near the driver side fender. The problem is the CHECK ENGINE light doesn't come on when I bypass the ECU by shorting the 2-pin connector, and I also don't notice there is a change in the RPM. I know ALLDATA sometimes mess up. Please tell me the right procedure to bypass the ECU. Also, I have a dyno program on my laptop, but it is only good for OBDII cars. What should I add or buy so I can use it on my OBD I CRX? Thanks for helping.
Old Jul 14, 2007 | 09:06 PM
SIred91's Avatar
Rainman
Default Re: problem regarding to setting the timing on CRX (kekekekevin)
What in the hell?
Old Jul 14, 2007 | 11:31 PM
PrimedoutCRX's Avatar
stock motor? if you have already done an OBD0 to OBD1 conversion that might be why you are having such problems.
Old Jul 15, 2007 | 01:56 AM
Default Re: problem regarding to setting the timing on CRX (PrimedoutCRX)
It is a stock motor, and I have never done any obd conversion. Plus. 2 of my friends have a 91 CRX Si and 89 CRX DX. we all have the same problem. bypassing the 2 pin timing adjusting connector and no check engine light comes on.
Old Jul 15, 2007 | 07:32 AM
Crx Jimmy's Avatar
just get it warmed up then set it, I couldn't get mine to light up the cel until I converted to obd1
Old Jul 15, 2007 | 07:38 AM
wiZCo's Avatar
Stouts 'n' Scotch
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kekekekevin &raquo;</TD></TR><TR><TD CLASS="quote">It is a stock motor, and I have never done any obd conversion. Plus. 2 of my friends have a 91 CRX Si and 89 CRX DX. we all have the same problem. bypassing the 2 pin timing adjusting connector and no check engine light comes on.</TD></TR></TABLE>
Then you're OBD0. I don't think the CEL is supposed to come on when jumpering the timing connector.
Old Jul 15, 2007 | 07:53 AM
VtecSyndrome's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kekekekevin &raquo;</TD></TR><TR><TD CLASS="quote">I have a 88 CRX SI. I am trying to set the timing. I follow the steps on ALLDATA. I can find the 2-pin cable near the driver side fender. The problem is the CHECK ENGINE light doesn't come on when I bypass the ECU by shorting the 2-pin connector, and I also don't notice there is a change in the RPM. I know ALLDATA sometimes mess up. Please tell me the right procedure to bypass the ECU. Also, I have a dyno program on my laptop, but it is only good for OBDII cars. What should I add or buy so I can use it on my OBD I CRX? Thanks for helping.</TD></TR></TABLE>
You say your REX is OBD 1 but it's stock.....................wrong! it's OBD 0 stock and what the hell is this about a timing connector to set the Cel??? to check your timing just get a freakin timing light and aim it at the crank!!! If your trying to get you CEL to come on via jumper then you need OBD 1 (which you don't have). not too mention your suppossd to check timing w/ a light.
you sound soooooooooooooooooooo confused.
Old Jul 15, 2007 | 11:43 AM
itsjusj0hn's Avatar
i've got problems with my timing too. found out that i have a sohc distributor runnign on my dohc. friend says that's the problem.
wesleywhite989
Jul 23, 2008 05:22 PM
1sikhatch
13
Oct 17, 2007 05:57 AM
ericracingpr
Jan 19, 2007 02:16 PM
Teluan
Aug 29, 2001 10:59 AM
