will bad alightment affect you on the track
planing to got to cmi on the 22nd, and i might not have enough money to get my alightment done, because it pulls to the left a lil. but will it cause me to run bad times?
it does.
it can cause you to be unstable, and if toe is too exagerated, you could be scrubbing while you do down the track.
It def will make the car unstable and not perform at it's best. Is it safe to run the car? It all depends on how bad the mis-aligment is and how fast the car is. It's gonna to be alot more unsafe/unstable if the car traps 135+ than 105mph.
Adriano
Adriano
Yes I know this for a Fact!!!
There are a lot of things that can go wrong to make you times higher
1. This can make you lose traction
2. Will cause you to loose power and make your motor work harder do to opposite
tire pull
3. will cause your lsd to be a joke.
Also this makes for poor gas mileage
Ha Ha
Oh Yea one other thing... you want your motor to pull your car down the track! Not try to fight you tires to make the car go....
tire pull
Ha Ha
driving the car down the track with the alignment out can cause you to steer with heavy correction the entire way down the track..My opinion would be to have it aligned just for saftey issues..Its bad enough to have correction from torque steer..
FAb5
Honda Civic (2006 - 2015)
83
Nov 28, 2009 06:46 AM
Honder07si
22
Sep 20, 2008 03:04 PM
fkncivic
15
Oct 6, 2003 04:07 AM
