H-series trans on F23A1
Old Jul 14, 2007 | 05:04 PM
hondamark35's Avatar
Default H-series trans on F23A1
i found a thread or two that said this was possible.
i just wanted to get some feedback from folks who have done this or have driven a car with this swap in it. kinda concerned how it does on the interstate and if the gear ratios are worth the effort. also any problems with the shifter hookup, axles, or clearancing issues? any other points you know of that are important if i decide to do this would be appreciated.
Old Jul 14, 2007 | 05:54 PM
overboostin's Avatar
Default Re: H-series trans on F23A1 (hondamark35)
yes it works and fits fine, i used a 98 h22 tranny and gears are shorter but pickup is a lot faster its ok as long as your ok with buzzin 4k at 80
Old Jul 14, 2007 | 09:58 PM
flight50's Avatar
Default Re: H-series trans on F23A1 (overboostin)
h series and f series trannies can be swapped out for one another.
Old Jul 15, 2007 | 04:00 AM
ok cool, yeah i don't mind 4k at 80. have you noticed any change in mileage or anything?
Old Jul 16, 2007 | 02:13 PM
nothing to complane about you just top out faster tho due to the f23 low red line
Old Jul 18, 2007 | 02:49 AM
YeuEmMaiMai's Avatar
Default Re: H-series trans on F23A1 (Mr Wonderfull)
that would drive me nuts..lol bees nest for the loss
Old Jul 18, 2007 | 03:26 AM
professorman's Avatar
Default Re: H-series trans on F23A1 (YeuEmMaiMai)
Your engine life might decrease a lil bit, because you engine will be spinning faster to go the same speeds as before. That is why Preludes engines don't last as long as Accords.
Old Jul 19, 2007 | 06:17 PM
thehatchninja's Avatar
Default Re: H-series trans on F23A1 (professorman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by professorman &raquo;</TD></TR><TR><TD CLASS="quote">Your engine life might decrease a lil bit, because you engine will be spinning faster to go the same speeds as before. That is why Preludes engines don't last as long as Accords. </TD></TR></TABLE>
haha...that's ridiculous. You're saying that the reason that Prelude engines don't last as long as Accord engines is because the run at a higher RPM on the interstate?
I'm sure it's more to do with the way they're driven (and maybe the auto t-belt tensioner)
Old Jul 19, 2007 | 07:47 PM
NASOHC's Avatar
Default Re: H-series trans on F23A1 (flight50)
I also heard about this swap a while ago but wasn't sure on what it involved. I'd love to the lower ratio trans if this is possible. Isn't the clutch kit also the same on these two trans. (F23A1 & H22/23) ???
Old Jul 19, 2007 | 08:28 PM
NASOHC's Avatar
Excuse my ignorance but what about the Hydraulic Clutch attachments?
Old Jul 19, 2007 | 08:38 PM
NASOHC's Avatar
You ARE wonderful! Any suggestions as to the exact application yr. & model so I can have my wrecking crew find a low mileage, thanks ahead!
Old Jul 21, 2007 | 05:35 AM
Default Re: H-series trans on F23A1 (thehatchninja)
i would have to agree mr. ninja.
people that drive preludes want it to be a race car. most people that drive accords want them to take them places.
Default Re: (Mr Wonderfull)
so do you have to use prelude axles or is it just better to use them?
Old Jul 25, 2007 | 07:42 PM
NASOHC's Avatar
Ok, so does it really matter then what year Prelude & Engine (H or F Series) the manual trans. came out of? I've read other posts where the claim the ratios to be different in some and advertise that they'll only work on 90-95 Accords. Please help as I'm really trying to find the best application. ALSO: Will it work with my stock ECU (manual trans.) on the 98' F23A1 Accord. Eventually I'm going to put in a Hondata ECU system but not just yet. Thanks again!
Missing Gears
Mar 19, 2011 07:12 PM
WillSB
May 4, 2009 08:25 PM
Romo Pyro
Apr 14, 2009 11:50 AM
accordtype R
Feb 13, 2006 01:50 PM
antivic
Jul 20, 2005 01:06 PM
