a6 block with a z6 head?
Old Jul 14, 2007 | 01:03 PM
widecrx's Avatar
Default a6 block with a z6 head?
so let me start. i got a 90 crx si with a d16a6 in it. the guy didnt know what was wrong with it. i pulled the head and found it had bent valves. so i was looking around for just another sohc and found a d16z6. i baught the z6, new dizzy for it, did a full tune up on it, got the kit from ry wire. i pulled the a6 out b/c it wouldnt start. i put the z6 in got it all wired and it would start... so i did a compression test on it and found that one was getting a low reading. i pulled the head and found the cylender wall was cracked!!!!!! so i have pulled that motor out now. so i have a good d16a6 block and a d16z6 head. I got them bolted togather but im not sure what dizzy to use. i tried the one from the z6 and the a6 and they dont line up. what dizzy should i get and is there anything else that i need to get for this swap? or is it just worth me getting a new sohc from h motos or somewhere?
Old Jul 14, 2007 | 02:26 PM
zcsport's Avatar
Default Re: a6 block with a z6 head? (widecrx)
you can use the a6 one with modification if you are using the pm6 ecu and along with the si injector and stuff
Old Jul 14, 2007 | 02:44 PM
mini-me-power's Avatar
Yea what are your plans? any boost or no, also what ECU are you planning on running.
Old Jul 14, 2007 | 04:41 PM
widecrx's Avatar
Default Re: (mini-me-power)
i have both the stock crx si ecu and a skunk 2 p28 ecu. the car is wired for the d16z6. im not doing any boost this summer but i will be boosting it over the winter.
Old Jul 15, 2007 | 05:19 AM
widecrx's Avatar
Default Re: (widecrx)
im hoping to use the z6 dizzy b/c its new. what do i need to do to get it to work?
Old Jul 15, 2007 | 08:07 AM
VtecSyndrome's Avatar
Why in the hell is your Z6 dizzy not bolting to your Z6 head??????? that makes no sense unless you broke something. your car is wired for OBD 1 to run the Z6 motor (or at least z6 head) and that means you HAVE to run your Z6 dizzy w/ your p28 ECU. sounds like you have everything you need except some common sense
Old Jul 15, 2007 | 10:20 AM
SIred91's Avatar
Rainman
Default Re: (VtecSyndrome)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecSyndrome &raquo;</TD></TR><TR><TD CLASS="quote">Why in the hell is your Z6 dizzy not bolting to your Z6 head??????? that makes no sense unless you broke something. your car is wired for OBD 1 to run the Z6 motor (or at least z6 head) and that means you HAVE to run your Z6 dizzy w/ your p28 ECU. sounds like you have everything you need except some common sense</TD></TR></TABLE>
I was gonna say the same thing but figured Id just let him bumble around...lol
Old Jul 15, 2007 | 10:38 AM
JLefevers's Avatar
Default Re: (SIred91)
^^ true true
Beasty91Hatchy
Oct 28, 2010 01:51 AM
toolbox21
Jun 22, 2008 11:57 AM
area608EG
May 17, 2008 03:31 PM
175Shot4Door
Oct 31, 2006 07:00 AM
1.8T_EG
Mar 29, 2003 11:09 AM
