ECU Blinks all the time
From: Commonwealth my ass This is the communist state, VA, USA
I was going down the highway running with an older 300zx and some big boat (never seen a car like this before couldn't read the name) at 100 mph on the speedo, I drop to fourth floor it for what seems like forever and I hit say 118 mph on the speedo, I shift to fifth and floor it another long wait and I hit what I seen as 123-4 on the speedo. All three cars slow down do to some traffic, We got passed it and I dropped to fourth again, I hit 110 and shift to fifth. I hold it for a while and the motor stumbles. I let go of the gas and try again,This time it dies at full throtle. I ease off and it picks up again at half throtle. Even With Down shifting I lost to much speed to stay on the road so I pull of to the side and slowly come to a chugging stop. The keys are on engine's dead, I try to start it and it starts to run then stops. I take a few to smoke a cig outside the car, Hop back in start it up and im on the road again. At midrange this time it kinda sputters, But gets past it. I look at the ECU when I get home and it just keeps flashing once every four seconds it does it while I drive too so I know it can't be a code.... Any ideas?????
TIA,
H8
TIA,
H8
Your computer is throwing a code, regardless of if you are driving your car or not. Let us know what the code is and then you can go and troubleshoot.
If it flashes once every 4 seconds, it sounds like your oxygen sensor is gone bad (code 1). Try cleaning your O2 sensor with some brake clean, and disconnect your battery for a minute or 2 to reset the ECU, then see if the drivability improves.
I counted as high as 37 (I got tired of counting)... Codes for a 91 civic dx only go to 20 right? It just keeps blinking the whole time i drive, until I turn the car off.
Thanks for your response,
H8
H8
I just replaced it with a universal one from advance about three weeks ago, It did show a code one after I replaced it though. Ill pull it out after work tonight. Is there any thing further up stream that would make the o2 sensor go bad, Say bad rings?
Thanks,
H8
Thanks,
H8
Mr. Choi
Sep 5, 2002 11:22 PM
