B20B Vs B20Z
Old Jul 14, 2007 | 08:10 AM
italianchooch88's Avatar
Default B20B Vs B20Z
now my plans are to go turbo right after this swap so im trying to figure out witch would be the best solution.i kno some b20s come with lower HP but are better for turbo because of compression.so what would be the best one for boost? b20b ,b20z jdm b20 ,usdm???i kno this has be proably covered be4 forgive me but i kno different years come with different hps and compression ratios
Old Jul 14, 2007 | 10:24 AM
bump
Old Jul 14, 2007 | 02:54 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: (italianchooch88)
http://www.hmotorsonline.com/s...it=25
The 96 - 98 model should be perfect if youd want to go boost
Old Jul 14, 2007 | 06:44 PM
so it would be better to go with the 126hp one with 8.8 compression than the 146hp one becuase of the higher 9.6 compression???
Old Jul 14, 2007 | 07:15 PM
fast forward driver's Avatar
i've seen a b20 pop a stock sleeve, get whatever you can , sleeve it , add pistons and rods, and alot of boost, the cheapest way aint always the best... unless you will be forever happy at 5psi
Old Jul 14, 2007 | 10:56 PM
im only goin to be boosting like 7 to 8 psi its going to be my daily driver..saw on a couple threads ppl boosting there stock b20's to 10psi with good tuning..but the 126hp would be a better swap than the 146hp one because the 8.8 compression is better for boost????????
Old Jul 15, 2007 | 01:26 AM
Fresh'86's Avatar
Lower compression = better boost.
I'm planning on picking up an LS motor for my car instead. I've read a lot on these motors, and I think you can create more power for less(safely) with an LS setup, but do as you think is best.
Old Jul 15, 2007 | 02:32 PM
well heres the thing i have an ls but the motors shot so reather rebulid it i figured i could just buy a b20 for cheaper than a rebuild and boost it..does any body have any numbers of b20s(b or z) vs. b18 with the same turbo setups??
Old Jul 19, 2007 | 11:46 AM
b18c1ej8's Avatar
Default Re: B20B Vs B20Z (italianchooch88)
i would rebuild ur ls becuase the b20s have thin cylinder walls and eventually if you wana go higher boost down the road you will be looking a rebuild anyway, so you might as well rebuild the one that can take more boost
Old Jul 21, 2007 | 09:58 AM
d357r0y's Avatar
Default Re: B20B Vs B20Z (b18c1ej8)
10:1 CR, 10psi, stock sleeves, 3 years, 0 problems.
TUNE
Old Jul 21, 2007 | 06:56 PM
Redline459's Avatar
i think the b201b as lower compession that might be better
Old Jul 22, 2007 | 12:02 PM
red02s2k's Avatar
Default Re: B20B Vs B20Z (Redline459)
i have a b20b 97 with a b16 head and i pulled 320 to the wheels on 11 pounds
Old Jul 22, 2007 | 11:26 PM
quicksilver1689's Avatar
i ♥ snails
yeah people take that stock sleeve thing way to far, yes there thinner 84mm vs 81, but if its not tuned right i dont care what thickness your sleeves are. Boost it, tune it, romp it! those b20's make made torque when turboed cuz turbos make torque, and torque makes fun!
Old Jul 22, 2007 | 11:34 PM
red02s2k's Avatar
Default Re: (quicksilver1689)
i just wanted to add a note.. sleeved or not sleeved it doesn't matter i had a sleeved b20 and when i went to the shop the sleeves shifted on the first pull on half a bar or 7 pounds.. i have seen stock sleeves pull 600 + hp on stock sleeves.....
Old Aug 15, 2007 | 07:24 PM
bluestreak_1's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by d357r0y &raquo;</TD></TR><TR><TD CLASS="quote">10:1 CR, 10psi, stock sleeves, 3 years, 0 problems.
TUNE </TD></TR></TABLE>
Exactly, a B20Z has the same, if not thicker side walls than a GSR, so don't buy the fact that all B20's are weak. The B20Z will have more compression, but Honda made the side walls thicker for the high compression b20z. Get a b20z, get a block guard to be safe, and have a good 225-250hp.
Old Aug 16, 2007 | 03:34 AM
sanjiyan69's Avatar
Default Re: B20B Vs B20Z (bluestreak_1)
just a quick question. if you see the link from hmotorsonline above, you'll see that they are selling 2 versions of b20b long blocks. So I'm assuming that the 99+ is b20z (usdm)?
slideintegra08
Aug 6, 2021 07:30 PM
B20vEFsedanBRUH
May 30, 2015 04:20 PM
EG6-MonSTa
13
Dec 20, 2009 12:47 AM
Mr.EGo
Jul 9, 2007 10:09 PM
blind
Jul 20, 2001 11:50 AM
