High Idle at cold, low idle at warm, shaky
Old Jul 14, 2007 | 02:41 AM
eg6yeee's Avatar
Default High Idle at cold, low idle at warm, shaky
the car used to idle at 2.5. i cleaned the IACV but the problem wasn't fixed. the CEL was code 7. so i replaced the entire TB. right after i installed the TB and started my car it was shaky but at 750pm. No more CEL
Next day
when i first start my car after overnight, it'll rev from 2.5-3.5 but will slowly reduces it's rpm after it gets warmer and stay at 750rpm. at 750rpm, it feels like it's not stable. engine is quite shaky and sometimes it'll drop down to 200 but it'll catch it's way up. if i don't drive my car after 3 hours. it'll repeat the same step, reving from 2.5-3.5 but without the rpm dropping from 200. it'll stay stable when it's completely warm. even when it's fully warmed up, the engine is still very shaky and the sound of it makes the car sound like it's in it's 70-80's. Car blows out black smoke and some sort of liquid, but the black smoke isn't thick. It isn't throwing a code. Any Ideas?
I've Clean/Changed IACV , TB, Spark plugs, and Fuel Filter.
Replies = Thank you.
eg6yeee's Avatar
Default Re: High Idle at cold, low idle at warm, shaky (eg6yeee)
1995 Integra LS only mod is intake.
Old Jul 14, 2007 | 05:36 PM
eg6yeee's Avatar
help please <33
Old Jul 15, 2007 | 05:00 AM
DC2R_JOE's Avatar
when you changed the TB, did you change the gasket?
Old Jul 15, 2007 | 01:58 PM
eg6yeee's Avatar
Default Re: High Idle at cold, low idle at warm, shaky (DC2R_JOE)
yeah it was changed
Old Jul 15, 2007 | 05:50 PM
adamrich33's Avatar
gets some carb cleaner and spray all vacuum connections if your idle lopes you got a leak
S33
Nov 18, 2014 02:08 PM
Hyde1
24
Apr 8, 2013 09:59 AM
pfsmith99
Oct 14, 2012 09:02 AM
kUrb3d
Aug 16, 2010 11:20 AM
