Brian Crower Stage 2 vs. 403 vs. 404 which one for streetable non-vtec?
I just souced out an LS block and got my rods. My sk2 IM and TB are already on the way. My final peice of the puzzle is camshafts. I have searched and searched but cannot find a comparison of these three cams. My goal is around 170+whp. The setup will be:
LS Block 1.8L
Pr3 Pistons 10.5:1 compression
Arias Forged Rods
Hand port/polish job on PR4 head
Skunk2 Intake Manifold
Skunk2 Throttle Body
Turbo Edit
????CAMS????
What do you guys think? I really want this car to be daily driveable. However, I don't mind a lopey idle. I have heard that the BC stage 2's come in between the 403 and 404's but end up producing more power. Does this make sense? This is what the BC dealer told me.
Please give me some constructive input as I need to order cams on MONDAY.
Thanks
LS Block 1.8L
Arias Forged Rods
Turbo Edit
????CAMS????
Thanks
Absloutley go with the 404's if ur gonna be running 10.5:1 comp. I ran 403"s on a stock ls bottom end with great results for the past 2 years. I made 149 whp with boltons and hondata so u should def. be in the 170 range with ur headwork and a good tune
The 404's are perfectly streetable with a good tune also. Hope this helps
nope, it doesnt have to be. tuning is just alot more important for them to idle well though.
heres mine
Click here to watch idle-58
Click here to watch b20z404idle
i have since played with the cam gears a bit more and it makes the idle worse.
heres mine
lilo_goki
13
Jun 23, 2008 09:36 AM
blackcrx16
11
Dec 18, 2007 07:39 AM
GreaseYankeedragger
Apr 4, 2004 05:40 AM
