recommendations
Old Jul 13, 2007 | 10:12 PM
medic4.life's Avatar
Default recommendations
ok on the f22b dohc jdm, need help on what needs to be replaced if engine only has 47k miles.
Its used i know i need to replaced the timing belt, timing belt tensioner, shaft tension belt and shaft tension tensioner pulley. water pump.
Im also replacing valve cover gasket and injector seals and oil pan gasket cuz the engine has been sitting their. But is it recommended to replace the oil pump, i noticed that i do need to basically tear apart the front of the engine just to place an oil pump.
Like i have replaced an oil pump before but that was on my old jetta which was just remove the oil pan and 3 screws.
Old Jul 14, 2007 | 07:24 AM
5_Lug_B's Avatar
* B A N N E D *
Default Re: recommendations (medic4.life)
If your doing all that already, Id say you might as well replace the oil pump while your at it.
Old Jul 14, 2007 | 10:12 PM
slowcivic2k's Avatar
47,000 is not a lot of miles, but if you got the money to sling a new oil pump, go ahead, I myself would clearance it and make sure it is within specs because I'm on a budget, and replace it only if I needed to.
Old Jul 15, 2007 | 12:36 AM
how can you tell when checking engines if the oil pump is still good?
Like i am on budget now due to my fall semester i needed to pay off
Old Jul 16, 2007 | 05:55 PM
bump
Old Jul 16, 2007 | 08:02 PM
Default Re: (medic4.life)
Take a feeler gauge and measure housing to rotor axial clearance, housing to outer rotor radial clearance, and the inner to outer rotor radial clearance.
If you need a bigger feeler gauge than a .009, chuck the pump...
rak511
Feb 26, 2014 04:02 AM
caliskier
Apr 9, 2012 01:05 PM
Origin
Jan 4, 2007 03:21 PM
snatch
12
Mar 15, 2005 10:12 AM
