compression test results
Old Jul 13, 2007 | 08:19 PM
JDMtype Eg6's Avatar
Default compression test results
i just bought a compression tester and did a compression test on my 97 gsr motor. I was just wondering what you guys think about the results.
200 195 170 195 any input or advice would help thanks.
Old Jul 13, 2007 | 09:25 PM
5_Lug_B's Avatar
* B A N N E D *
Default Re: compression test results (JDMtype Eg6)
Those are some pretty decent numbers, except for #3. Id get it checked out.
Old Jul 13, 2007 | 10:22 PM
id also like to state that when i pulled my plugs out #2 and 3 had oil at the bottom of the plugs. Could it be worn valve seals? havent driven my car in a few months beacause a motorcycle hit me when i had it. The motor also tend to burn oil and white smoke use to come out of my exhaust when i was in high rpms (5500-8k). Tommorow im going to do another compression test and add some oil in each cyl to c if the compression raises due to bad rings.
Old Jul 14, 2007 | 02:31 AM
bobjohnson's Avatar
White is usually coolant... You sure it wasnt blue? Shouldnt have a bad head gasket if your compression numbers look like that....
MarkCayabyab
10
Oct 29, 2013 06:18 PM
SilkyJohnson
13
Feb 15, 2011 05:54 PM
vipokc
Feb 4, 2009 06:57 AM
95greenlude
Nov 3, 2007 04:21 PM
climb_on
Jul 29, 2007 03:40 PM
