JDM headlights with aftermarket HID kit. Questions
Old Jul 13, 2007 | 08:12 PM
WannaHonda's Avatar
Default JDM headlights with aftermarket HID kit. Questions
I recently installed my jdm front end with the non HID headlights. I plan on buying a set of HID's for them. Before I begin to rewire, I have a couple of questions. I was told that I should purchase a set of HID's with ballasts that were made for the USDM front end, and get bulbs for the JDM headlights. With that setup, I would not have to rewire the headlight setup. Is that true? Anyone have any advice on what I should do, or any info on how to wire the JDM headlights with aftermarket HID's. Thanks.
Old Jul 13, 2007 | 08:55 PM
TYPE-R#945's Avatar
Default Re: JDM headlights with aftermarket HID kit. Questions (WannaHonda)
if you were going to buy the oem HID then they wont fit your headlight unless you buy the oem HID headlight assembly , but if your short on funds then get the ebay hid kits, they are pretty cheap and your bulb size will be a 9006.
Old Jul 13, 2007 | 11:59 PM
98itRspec's Avatar
putting a hid kit on a oem jdm non hid is ugly IMO, the cut off is ugly. you have to do alot of adjusting. good luck if you do
Old Jul 14, 2007 | 02:50 AM
urosch's Avatar
Default Re: JDM headlights with aftermarket HID kit. Questions (98itRspec)
It isn`t that ugly.
Just buy 9006 HID kit, install it and you`ll be fine. If it is too high just take a screwdriver and adjust it a bit.
Old Jul 14, 2007 | 04:07 AM
ITR32's Avatar
Default Re: JDM headlights with aftermarket HID kit. Questions (urosch)
What number did you go with 6000, 8000
Old Jul 14, 2007 | 07:18 AM
jdmsta's Avatar
i had that kind of set up before i finally invested on the real JDM HID headlights assembly...you're much better off buying the real hid headlight assemblies...i have people flashing their high beams at me all the time even when i aimed the beams low because there's no cutoff lines or anything...the beams look like it was from a reflectors headlamp instead of a projectors...just my 2 cents
Old Jul 14, 2007 | 07:58 AM
pvt_awol's Avatar
Default Re: JDM headlights with aftermarket HID kit. Questions (jdmsta)
hell, I get people flashing me with my authentic HID front end anyway.
Old Jul 14, 2007 | 09:26 AM
DC4KiD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98itRspec &raquo;</TD></TR><TR><TD CLASS="quote">putting a hid kit on a oem jdm non hid is ugly IMO, the cut off is ugly. you have to do alot of adjusting. good luck if you do </TD></TR></TABLE>
No it's not, and you don't have to do a lot of adjusting.
The OEM projector in those non-HID headlights are pretty good for aftermarket HID setups. The cut-off is pretty clean with only 1 hot spot on each light.
Old Jul 14, 2007 | 09:53 AM
Locc's Avatar
Default Re: JDM headlights with aftermarket HID kit. Questions (DC4KiD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC4KiD &raquo;</TD></TR><TR><TD CLASS="quote">
The OEM projector in those non-HID headlights are pretty good for aftermarket HID setups. The cut-off is pretty clean with only 1 hot spot on each light.</TD></TR></TABLE>
Old Jul 14, 2007 | 04:16 PM
CDN Yellow ITR's Avatar
whats a hot spot???
Old Jul 14, 2007 | 04:21 PM
Jon D's Avatar
Default Re: (CDN Yellow ITR)
Why doesn't anyone seem to understand that HID kits vs a HID retrofit or a car that comes equipped with HIDs are two completely different things.
The projector makes all of the difference, it doesn't matter what fuggin color bulbs you use. A projector designed for a halogen based bulb such as the DC2 isn't going to yield the same results as a projector designed for an HID bulb.
Yes... you are getting the look, but surely not the function.
Old Jul 14, 2007 | 07:58 PM
WannaHonda's Avatar
What i was asking though was do I need to but a kit for a usdm ITR, or a kit for the headlights? Trying to figure out what I need to do the get the headlights wired up. Thanks for all the input.
Old Jul 14, 2007 | 08:03 PM
DC4KiD's Avatar
Default Re: (WannaHonda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CDN Yellow ITR &raquo;</TD></TR><TR><TD CLASS="quote">whats a hot spot???</TD></TR></TABLE>
A spot where the lighting is brighter than the other areas.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WannaHonda &raquo;</TD></TR><TR><TD CLASS="quote">What i was asking though was do I need to but a kit for a usdm ITR, or a kit for the headlights? Trying to figure out what I need to do the get the headlights wired up. Thanks for all the input.</TD></TR></TABLE>
USDM & JDM uses the same low beam... 9006
gtrwerks
Jul 1, 2009 05:08 PM
JDMStilez
Feb 4, 2005 04:46 PM
JSPECHB
Dec 28, 2004 06:06 PM
dc2_tuner
Sep 4, 2004 10:33 AM
rough_draft
Jun 4, 2004 03:20 AM
