Could this be pulled out on a rack?
Old Jul 13, 2007 | 05:00 PM
Orangegsx's Avatar
Default Could this be pulled out on a rack?
need opinions, I can get all the parts and the radiator still fits in fine. The car drives straight still. But my right fender is tweaked so the hood will not fit in. Compared to the other rail this one looks like it's about 2 inches over. Think it could be pulled out easily? thanks
Old Jul 13, 2007 | 05:28 PM
SIred91's Avatar
Rainman
Default Re: Could this be pulled out on a rack? (Orangegsx)
OUCH......but, yeah its doable, but it aint easy.
Old Jul 13, 2007 | 06:04 PM
Orangegsx's Avatar
Default Re: Could this be pulled out on a rack? (SIred91)
hopefull it'll come out good. It kinda sucks because I bought the car and it had no bumper supports, i think it would have been a lot better with one on there. I work at a honda dealership so hopefully I can get a deal pulling the frame
Old Jul 13, 2007 | 06:05 PM
CRX Toad's Avatar
A new radiator core support (not bad) and then a little pull on the corner.
Old Jul 13, 2007 | 06:18 PM
wiZCo's Avatar
Stouts 'n' Scotch
Default Re: Could this be pulled out on a rack? (CRX Toad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">A new radiator core support (not bad) and then a little pull on the corner. </TD></TR></TABLE>
x2, it looked like the bulkhead absorbed most of the damage. As long as the subframe is OK, shouldn't be too much of a hassle.
Old Jul 13, 2007 | 06:21 PM
godruler's Avatar
i do frame work for a living and thats really not a bad hit at all, those cars are so weak you could draw and quarter them literally with 4 towers if you really wanted to. you could probrably just cut the rad support out and port-o-power the rail back to place until the re-bar will bolt on then just square up the nose to make sure its not swayed and weld the new support in. easily fixable in just over half a day.
modulo_s
Aug 7, 2007 05:03 PM
LiViNgLeGeNd
Dec 7, 2005 02:27 PM
jeffk182
23
Apr 27, 2005 01:07 PM
Mr. JDM-GSR
11
Sep 20, 2004 10:03 AM
eg6T
Sep 1, 2004 12:38 PM
