rev problem, 00 civic ex with si swap wont rev past 4,000 rpm, slow rev and bog
i have a 2000 civic ex and recently swapped in a 92-95 b16a.
i started the car and the car will hit the rev limiter at 4,000, its throwing codes like 21, 4, and 42.when i first started it the rev was off a bit and it would go high then low with the check engine light on the whole time!, then it went away and hasnt done it since the code that it would throw is the crank angle sensor. i switched from a p28 to a po6 ls ecu i think and it did the same thing
this problem is very frustrating and i can use any tips or help i can get I need tips or answers !ASAP
4 CKP - crank position sensor
21 VTEC spool solenoid valve
and are you SURE its 42???
IM SORRY I MEANT 7, i know what they all mean i just dont know what the problem is.
i checked the timing,plugs,grounds,whatever the code was i checked it if i could. i kept resetting the ecu AND NOW ITS ALL GONE BUT THE 4 NO SOLUTION YET !
CHECK ENGINE LIGHT IS ALWAYS ON WHEN IGNITION IS TURNED ON.
THIS B-S IS GETTING ME P-O'D
civic_freak
Jun 10, 2005 03:51 AM
