Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
Automatic Transmsission Drain Plug is really tight
Old Jul 13, 2007 | 11:52 AM
vat0213's Avatar
Default Automatic Transmsission Drain Plug is really tight
I've been trying for a day and a half now, with the 3/8 ratchet, to take out but it is not giving at all. Did anybody have that trouble? Also its not a reverse thread is it? Does anyone have any tips? Forgive me, I am a noob by all means. Thanks.
Old Jul 13, 2007 | 05:55 PM
susuking's Avatar
lefty tighty, righty loosey
.. anyway, try using a rachet with a hammer carefully and slowly whack it once or twice to loosen it a little bit
Old Jul 14, 2007 | 04:54 AM
Newborn_'s Avatar
Grace Under Pressure
Default Re: (susuking)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by susuking &raquo;</TD></TR><TR><TD CLASS="quote">lefty tighty, righty loosey
O RLY? Reckon you'd better re-think that one. Jesus...
And how the hell do you whack something slowly?
OP, what have you been using to try and undo it? Try a 1/2" drive socket on a 12 or 18in breaker bar - but if the plug is only 6 sided, use a 6 sided socket on it rather than bi-hex (12 sided) as you'll have less chance of slipping and skinning your knuckles or rounding off the bung.
Old Jul 14, 2007 | 08:09 AM
DankasCivic's Avatar
righty tighty lefty loosey
Old Jul 14, 2007 | 09:49 AM
Vantage's Avatar
breaker bars can be your friend.
Old Jul 14, 2007 | 01:45 PM
Honda Rules's Avatar
Default Re: (Vantage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Vantage &raquo;</TD></TR><TR><TD CLASS="quote">breaker bars can be your friend.</TD></TR></TABLE>
Old Jul 15, 2007 | 12:52 AM
burnout8488's Avatar
Default Re: (ONLYuk7thGen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ONLYuk7thGen &raquo;</TD></TR><TR><TD CLASS="quote">OP, what have you been using to try and undo it? Try a 1/2" drive socket on a 12 or 18in breaker bar - but if the plug is only 6 sided, use a 6 sided socket on it rather than bi-hex (12 sided) as you'll have less chance of slipping and skinning your knuckles or rounding off the bung.</TD></TR></TABLE>
The drain plug accepts a 3/8" ratchet. There isn't a socket you can put on the drain plug.
Put a pipe on the end of the ratchet. It'll crack off eventually.
Old Jul 15, 2007 | 03:48 AM
Newborn_'s Avatar
Default Re: (burnout8488)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by burnout8488 &raquo;</TD></TR><TR><TD CLASS="quote">
Put a pipe on the end of the ratchet. It'll crack off eventually.</TD></TR></TABLE>
Fair enough bud, i've never seen one to be honest. If you're still struggling in that case, just use a 3/8" breaker bar then.
92civicx
Sep 18, 2007 04:44 PM
Blamm!!
Dec 28, 2006 03:16 PM
Touge Tuning
Oct 12, 2006 01:55 PM
SimbaDogg
Dec 21, 2003 06:25 AM
Matgallis
Nov 10, 2003 01:19 PM
