What could it be?
Old Jul 13, 2007 | 08:03 AM
bmxbikes's Avatar
Default What could it be?
Ok bought a crx and the owner told me it needed a new igniter as he started it and the spark plug wires shorted out on the valve cover. Well I bought a new igniter and no spark. Bought a new distributor and no spark. So i tried a lot of different things(checked the main relay so dont say that) and finally just took it to a mechanic. Turns out the distributor I had bought had a bent rotor or something and they replaced it. Now I get spark. They said I only get it when the car is on and when you turn it over I get no spark. Not sure what that means but he said he had it running 3 times yesterday. Now hes checked the timing and its fine, checked the starter components and its fine. Now hes wondering if its ecu related or wiring. I really am worried about if this car is just done for or not. Any ideas what it could be? When I had it and it wouldnt start i could turn it on and the CEL would come on for a second then click off so i didnt have any codes. Not sure what could be wrong
Old Jul 13, 2007 | 08:13 AM
SIred91's Avatar
Rainman
Default Re: What could it be? (bmxbikes)
Wow....has it been swapped or modded in any way? What model is it?
DPFI? MPFI? stock wiring and ecu?
Old Jul 13, 2007 | 08:14 AM
bmxbikes's Avatar
Its a stock 89 DX.
SIred91's Avatar
Rainman
Default Re: What could it be? (SIred91)
Get the ignition switch tested or swapped....the switch itself, not where the key goes.
Old Jul 13, 2007 | 07:27 PM
bmxbikes's Avatar
any other ideas?
Sturg
Oct 27, 2009 12:04 AM
bmxbikes
Jun 26, 2007 07:26 PM
2.2lude88
Jul 3, 2006 05:21 PM
nigel
10
Feb 2, 2004 12:50 PM
Ri5e
Apr 4, 2002 12:20 PM
