88 Crx wont turn off
Old Jul 13, 2007 | 02:46 AM
94gsrhatch's Avatar
Default B16 swap cant get pass side axle in
Hey guys, I know I haven't posted alost but I read this fourm every day and you all are great people and a great source of information!.
Here is the deal, I have a 88 Crx DX, just today I started her up after a DPFI to MPFI and added vtec. Used write ups from honda-tech to accomplish this. Car started fine after not runing for 7 months. Throwing code 8 (TDC Sensor) and 15 (ingition signal sensor) still trying to figure out how to fix these. car is runing a chiped pr3 ecu with modified dx harness.
When turning the key to off the car still runs. I've searched but i haven't been able to find anything.
One other thing is that im trying to get the pass axle in, i've tired 3 diffrent axles all in the years of 90-93 integra. It needs to go in about 3/4inch more into the tranny but will not budge. The tranny is a j1 with a ls 5th and a LS top half of the tranny. Should i be having these problems? Any help would be great guys! let the rex live been sleeping for to long!!
Thanks yall
Modified by 94gsrhatch at 10:18 PM 7/13/2007
Modified by 94gsrhatch at 11:43 PM 7/13/2007
Old Jul 13, 2007 | 09:08 AM
hondacivic90zc's Avatar
Default Re: 88 Crx wont turn off (94gsrhatch)
my only guess would be the ignition switch but i am not completely sure.
Old Jul 13, 2007 | 09:44 AM
94gsrhatch's Avatar
The only part about the wiring i was kinda confused about was runing a wire from A15 to the resistor box, i taped that wire at the ecu and ran it, could that be a problem?
Sal
Old Jul 13, 2007 | 10:32 AM
i honestly am not sure but there has to be somebody on here that knows.
Old Jul 13, 2007 | 01:19 PM
94gsrhatch's Avatar
Default Re: 88 Crx wont turn off (iandavis90)
bump
Old Jul 13, 2007 | 03:45 PM
zcsport's Avatar
Default Re: B16 swap cant get pass side axle in (94gsrhatch)
i have exactly the same code like you ,i fix my code 15 i guess but still have to work on my code 8,what dizzy u using,??8 is tdc and 15 is ignitor!!
Old Jul 14, 2007 | 11:17 AM
94gsrhatch's Avatar
Default Re: B16 swap cant get pass side axle in (zcsport)
not sure what kind of dizzy, the dizzy is less then one year old though. I got the axle in the car and she's moving and driving nicely. ITR 4-1s sound nice. my only real big concern right now is that i cannot turn it off by the KEY! i keep pulling the plug on the dizzy for it to shut off! I have no idea.
Little help guys?
Sal
Old Jul 14, 2007 | 11:48 AM
placid888's Avatar
when u turn off the ignition, is the guage cluster turn off also?? is the temperature guage and rpm guage still operating??
Old Jul 14, 2007 | 12:52 PM
94gsrhatch's Avatar
Default Re: B16 swap cant get pass side axle in (placid888)
Yes when i turn the car off the guage cluster turns off as well. I just went for a drive and then the tach, temp, and gas guage stoped working. Noticed i blew fuse #1 i belive, changed it. The cluster started working untill i turned the car on and it blew again. One problem after another damn cars! hah. Im mind boggled about now!
Thanks guys!!
Sal
goobous
Mar 20, 2011 08:55 AM
Nose
Mar 21, 2007 11:47 AM
Schaz
Jun 22, 2005 01:44 AM
iNetForce
Mar 27, 2004 12:41 PM
