Ok to use lower compression ratio ?
Old Jul 12, 2007 | 11:20 PM
EJ8ona's Avatar
Default Ok to use lower compression ratio ?
I am planning on doing a GSR swap into my civic with future plans to turbo it. I want to know if it is OK to build the bottom end now, sleeved with a 9:1 or 9.5:1 compression ratio , without running the turbo kit ? Would I need to get it tuned or would a regular ECU be able to run it right ? And would it still be suitable to drive as this is my daily driver ? Any info or insight would be great !!!
Old Jul 13, 2007 | 12:21 AM
dannis.'s Avatar
Default Re: Ok to use lower compression ratio ? (EJ8ona)
you dont have to worry about anything. only thing is, your going to lose a bit of go power untill you slap that turbo on.
Old Jul 13, 2007 | 12:35 AM
MasterShake's Avatar
^^^ x2
Old Jul 13, 2007 | 07:13 PM
EJ8ona's Avatar
Thanks for the info. Hopefully I won't have to wait to long to boost it !
civic-r11
Mar 31, 2009 12:04 PM
kool168
Mar 5, 2004 03:42 AM
Doug684
Dec 30, 2003 09:59 AM
MUGENTYPER
Feb 6, 2002 06:31 AM
